ctr climate cluster install into 99 si ..question
Old Sep 30, 2004 | 03:40 PM
mumbler44's Avatar
Default ctr climate cluster install into 99 si ..question
i am thinking about installing the ctr cluster into my si.. i have a few questions
is there any cutting involved or is it fairly easy to do??
is it as easy as just moving the vent,s *****, and appropiate wires??
thanks for the help
Old Oct 1, 2004 | 08:07 AM
mumbler44's Avatar
help
Old Oct 1, 2004 | 08:16 AM
Solscud007's Avatar
Default Re: ctr climate cluster install into 99 si ..question (mumbler44)
I dont think it will work. Well depends on which CTR you are using. If it is JDM or UKDM (england) then I dont think it will work. These cars are right hand drive right? so their entire console is mirrored to yours. So things like the climate control are ont eh righ not the left. Now the hardest part and the biggest problem i for see would be the vents. Your vents are to the right. (I have a 98 civic and was thinking of jsut swapping out the climate control console too but the vensts wont line up) You need to replace the vent ducts themselves.
Old Oct 1, 2004 | 08:36 AM
kurisuchan's Avatar
the EK9 ctr climate control _bezel_ bolts right up.
Old Oct 1, 2004 | 08:38 AM
kurisuchan's Avatar
Default Re: ctr climate cluster install into 99 si ..question (Solscud007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solscud007 &raquo;</TD></TR><TR><TD CLASS="quote">I dont think it will work. Well depends on which CTR you are using. If it is JDM or UKDM (england) then I dont think it will work. These cars are right hand drive right? so their entire console is mirrored to yours. So things like the climate control are ont eh righ not the left. Now the hardest part and the biggest problem i for see would be the vents. Your vents are to the right. (I have a 98 civic and was thinking of jsut swapping out the climate control console too but the vensts wont line up) You need to replace the vent ducts themselves.</TD></TR></TABLE>
he has a '99 si as stated in the topic title.
96dxpower
Northern California (Sales)
Sep 22, 2008 08:06 AM
Agent_EM1
May 16, 2007 10:05 PM
4drferio
Feb 25, 2007 12:06 AM
4drferio
Feb 23, 2007 01:22 PM
B18Sleeper
Jan 14, 2007 07:56 PM
