bad lmas lost motion assemblys
Bad LMAs are annoying.. yes. Nothing to worry about driving with them? All they do when they go bad is annoy the hell out of you... and thats all? thanks for input!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">not too sure what damage it may cause though. </TD></TR></TABLE>
Thats what i'd like to know.
Bump
Bump
might cause a little wear on your vtec lobe from the rocker tapping against it, and not being in constant contact with it. But hell i changed mine out and sounds fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hahagasdcrx »</TD></TR><TR><TD CLASS="quote">might cause a little wear on your vtec lobe from the rocker tapping against it, and not being in constant contact with it. But hell i changed mine out and sounds fine.</TD></TR></TABLE>
Yeah, I changed mine right away, not only was it embarassing but I didn't exactly know if it would damage anything soI didn't want to take any chances.
alot of stuff has to be removed.
to save you some time here's the P# for some for a 99 Civic Si:
14820-P30-010
you can use the ones for GSR's, Type-R's, and Del Sol VTEC's also, i think. The only ones w/ different part numbers are the GSR's and Type-R's I believe, but im just a SOHC guy.
14820-P30-010
corrections:
97 Integra GS-R
14820-P30-010
98 Integra Type-R
14820-P73-J01
00 Integra Type-R
14820-P73-J01
00 Civic SI B16a
14820-P30-010
JDM B16b Civic Type-R
14820-P73-J01
JDM 96 Integra Type-R
14820-P73-J01
say thanks to google, heres the p#'s
97 Integra GS-R
14820-P30-010
98 Integra Type-R
14820-P73-J01
00 Integra Type-R
14820-P73-J01
00 Civic SI B16a
14820-P30-010
14820-P73-J01
14820-P73-J01
if I do change them they will be h22 Lmas, using omni's method. My engine just went backt together again, might be a while before I changed them out... just wanted to know if bad lmas will do more than annoy someone,
From: I told you to wait in the truck in Texas, United States
so im guessing i'll be fine riding around with bad LMAs? I don't think its going to hurt the OEM cams any. besides that, I dont know what else they would cause to fail.
Mine are loud as hell, people everywhere ask me whats wrong with my engine.. oh well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n00bs suck »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
What's the bump for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">What's the bump for? </TD></TR></TABLE>
It gets the post back up to the top.
