brake line replacement
Old Sep 30, 2004 | 10:26 AM
anekin007's Avatar
Default brake line replacement
im going to upgrade my brake system on my 00 si. im getting brembo blanks all around and axxis MM pads. im going to get some stoptech ss lines. my question is, should i just replace the front lines only? or should i replace the rear lines also? also..what brake fluid would ya recommend...
Old Sep 30, 2004 | 11:12 AM
jbs's Avatar
jbs
Default Re: brake line replacement (anekin007)
Replace all 4 lines please.
Old Sep 30, 2004 | 11:16 AM
Jon V's Avatar
Default Re: brake line replacement (jbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs &raquo;</TD></TR><TR><TD CLASS="quote">Replace all 4 lines please. </TD></TR></TABLE>
I use ATE super blue and have no complaints.
Old Sep 30, 2004 | 11:17 AM
wilsel's Avatar
Default Re: brake line replacement (Jon V)
Do they even sell just the front? Every kit I've ever seen comes with all 4 lines.
Old Sep 30, 2004 | 11:23 AM
pdiggitydogg's Avatar
Default Re: brake line replacement (wilsel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wilsel &raquo;</TD></TR><TR><TD CLASS="quote">Do they even sell just the front? Every kit I've ever seen comes with all 4 lines.</TD></TR></TABLE>
Exactly
I also use ate super blue w/ no complaints
Old Sep 30, 2004 | 12:42 PM
R Thizzel's Avatar
i have the same set up well not blanks but they r slotted and i replaced all 4 lines with steel braided and use the super blue. all in all works pretty good but the lines for the rear brakes r different from the front jus to let u kno.
Edit: also be sure to keep a close eye on ur rotors because the metal masters will put grooves in ur rotors due to the wear of the zinc coating. they put quarter inch grooves in my friends rotors but he switched to organic pads and has no complaints.
Old Sep 30, 2004 | 01:22 PM
anekin007's Avatar
Default Re: brake line replacement (R Thizzel)
lol..ok..i always thought they came in pairs..
i thought the brembo blanks were not coated with zinc..the only ones i hear that are coated with zinc are the brembo that were third party cross drilled or slotted.
Old Sep 30, 2004 | 01:24 PM
Jon V's Avatar
I got a set of 96-00 SI 4 wheel disc SS braided lines if you are lookin for some...
Old Sep 30, 2004 | 07:47 PM
R Thizzel's Avatar
u could be rite. i have the slotted rotors and my friend has the combination. even still, im not happy with the pads. dust is a pain in the *** just like all pads but it seems like i have the same ones they use on bmw 3 series sucks
but damn if i had the money, id go endless
bb4ninja
Apr 19, 2006 08:11 AM
StatGSR
Apr 28, 2005 12:55 PM
piotrush
33
Dec 3, 2003 09:16 AM
B2FiNiTY
32
Aug 6, 2003 02:21 PM
lanceh
Apr 18, 2003 09:22 AM
