Need immediate axle help!!!
Old Sep 30, 2004 | 08:49 AM
g2lsv's Avatar
Default Need immediate axle help!!!
Last night i was driving and at one point took a u-turn and my car would just rev in place. I tried swithing gears and trying to go but it just reved. All my gears still work and my clutch works. So i was wondering it is is the axle that is mest up. And if it is do you guys know where i could get a 91 integra axle OEM for cheap. Thanx a lot for the help
Old Sep 30, 2004 | 08:55 AM
Kendall's Avatar
For it to be the axle, it either isn't there, or it's fubared beyond any reasonable belief.
Old Sep 30, 2004 | 09:04 AM
JimBlake's Avatar
Default Re: (Kendall)
Here's some possibilities for you to check out.
Did you grind off the splines where the axle shaft inserts into the outer CV joint? Once they're smoothed out, the axle can spin in place without turning the wheel. I suppose it would make ugly noises when it first failed. If this is it, you'll see one of your axles spinning without driving it's wheel.
Did you grind off the splines at the inboard end of an axle. Same story, but you won't see any axles spinning.
Loose teeth from the differential ring gear? That would be nasty, noisy, & probably not very likely???
Break the hub of your clutch disk? Usually a spring or some shrapnel gets itself wedged into the pressure plate, then you can't DISengage your clutch. Besides, that usually makes the clutch pedal feel different.
Grind off the splines of the tranny input shaft where they go into the clutch disk?
Old Oct 1, 2004 | 08:20 AM
integra15's Avatar
Default Re: Need immediate axle help!!! (g2lsv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2lsv &raquo;</TD></TR><TR><TD CLASS="quote">Last night i was driving and at one point took a u-turn and my car would just rev in place. I tried swithing gears and trying to go but it just reved. All my gears still work and my clutch works. So i was wondering it is is the axle that is mest up. And if it is do you guys know where i could get a 91 integra axle OEM for cheap. Thanx a lot for the help</TD></TR></TABLE>
You can get them cheap at Autozone, but they are remanufactured
Old Oct 1, 2004 | 08:24 AM
timmy8151's Avatar
Default Re: Need immediate axle help!!! (integra15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra15 &raquo;</TD></TR><TR><TD CLASS="quote">
You can get them cheap at Autozone, but they are remanufactured </TD></TR></TABLE>
You can get new GCK axles at Autozone too. They also come with a lifetime warranty and are about $100/axle.
ralphieg
Oct 2, 2012 06:36 PM
CoolRedXylophone
10
Dec 15, 2009 03:17 PM
Audi RS4
Sep 10, 2003 02:04 PM
ill phil
May 15, 2003 06:27 PM
philipkrotch
Jan 22, 2003 10:46 AM
