Turbo GSR CRX (vw beetle exhaust)
Old Sep 30, 2004 | 07:35 AM
TurboEH2's Avatar
Default Turbo GSR CRX (vw beetle exhaust)
this is my buddy's "racecar" it is an 1988 CRX HF with a GSR turbo setup. running an ITR trans. This is his VW Beetle exhaust impersonation. Tell me what ya think
ps he isnt really leaving it like that. its just for ***** and giggles and i figured u guys would get a good laugh out of it.
Old Sep 30, 2004 | 07:37 AM
RedTT's Avatar
Default Re: Turbo GSR CRX (LSturboEH2)
backpressure!!!
Old Sep 30, 2004 | 07:39 AM
Cimburke23's Avatar
Default Re: Turbo GSR CRX (RedTT)
backpressure? how? ram air pressure is more like it, and its mine by the way
Old Sep 30, 2004 | 08:00 AM
SSBPGSR's Avatar
Default Re: Turbo GSR CRX (Cimburke23)
that looks, weird. i hope u dont mind black crap all over ur bumper, hood, windsheild and roof! i guess it would blend in with the paint, and u wont even notice it
Old Sep 30, 2004 | 08:05 AM
Vanilla Ic3's Avatar
Default Re: Turbo GSR CRX (SSBPGSR)
Fools. All he need do is shift into R, presto- problems all solved.
Old Sep 30, 2004 | 08:15 AM
BlackRocket's Avatar
i think its pretty cool and creative
just outa curiousity, can you give me the specs on your motor and what abouts you run in the quarter mile, i want to do the same setup (gsr turbo) and i just want to see what your running thanx
Old Sep 30, 2004 | 08:16 AM
also tell us how that exhaust goes im kinda curious to see if it works or helps
Old Sep 30, 2004 | 08:28 AM
TurboEH2's Avatar
Default Re: (screamingsr21)
it is a stock gsr engine, Cimburke23 is the owner. he had the swap with a different (not-so-liked bt H-T) manifold. he put down like 252whp at 6psi (it is in his sig). and i think u guys might have missed the PS at the bottom. he put it on that way for ***** and giggles. this was the former exhaust he had on the del slo with this engine and turbo. but he cut it off and with the drag mani he had to flip the turbo around the other way so it would clear the block. here is a link to the del slo when it had the gsr in it. GSR TURBO DEL SLO
Modified by LSturboEH2 at 5:40 PM 9/30/2004
Old Sep 30, 2004 | 08:32 AM
thanx for the specs bro
Old Sep 30, 2004 | 08:35 AM
EJ1 wilcox's Avatar
That would be fun to pull up behind a white car and start reving...
haha
Old Sep 30, 2004 | 09:22 AM
racinskittle's Avatar
Default Re: (EJ1 wilcox)
that O2 sensor's kinda far away from the outlet of the turbo. Did that work ok for your setup? i was running that same way with open downpipe on my sol, and it threw and O2 code and wouldn't read right.
But im sure w/a full exhaust it'd be diff. Just kinda curious
Old Sep 30, 2004 | 09:55 AM
EM1 MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR &raquo;</TD></TR><TR><TD CLASS="quote">that looks, weird. i hope u dont mind black crap all over ur bumper, hood, windsheild and roof! i guess it would blend in with the paint, and u wont even notice it </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSturboEH2 &raquo;</TD></TR><TR><TD CLASS="quote">ps he isnt really leaving it like that. its just for ***** and giggles and i figured u guys would get a good laugh out of it. </TD></TR></TABLE>
Old Sep 30, 2004 | 10:39 AM
Johnyquest's Avatar
Default Re: Turbo GSR CRX (EM1 MIKE)
My 02 is relocated right before the cat in my stock D and it reads fine
Matt
tgreaves's Avatar
Start it up and record it.. That has got to be loud as ****..
Old Sep 30, 2004 | 10:56 AM
TurboEH2's Avatar
Default Re: Turbo GSR CRX (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Start it up and record it.. That has got to be loud as ****..</TD></TR></TABLE>
ill see what i can do.
Old Sep 30, 2004 | 10:58 AM
tgreaves's Avatar
ill see what i can do. </TD></TR></TABLE>
Screw it.. Drive it around the block and lets hear what it sounds like spooling up..
Just dont forget to put the charge pipes back on..
Old Sep 30, 2004 | 11:00 AM
m R g S r's Avatar
Probally sounds like my open downipie! I will get some vid's of mine too. I love being able to hear VTEC pop on and off.
Old Sep 30, 2004 | 11:01 AM
tgreaves's Avatar
Default Re: Turbo GSR CRX (m R g S r)
Hit a 2-step with anti-lag and you can cook some hotdogs with it..
Old Sep 30, 2004 | 11:31 AM
*Boostwerks*'s Avatar
WTF?...Hahahaa
Old Sep 30, 2004 | 11:46 AM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cimburke23 &raquo;</TD></TR><TR><TD CLASS="quote">backpressure? how? ram air pressure is more like it, and its mine by the way</TD></TR></TABLE>
cool?
Old Sep 30, 2004 | 12:02 PM
Boltz's Avatar
That has got to be the dumbest thing ive ever seen. Waste of wire, gas, and my time for clicking on, and now replying to this post. So why would you even waste your time? Also I would put money on it that the placement of the o2 sensor will give you tampered results because the o2 is about 2 inches from the end of the pipe, not to mention you would be forcing clean air into the pipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screamingsr21 &raquo;</TD></TR><TR><TD CLASS="quote">i think its pretty cool and creative
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screamingsr21 &raquo;</TD></TR><TR><TD CLASS="quote">also tell us how that exhaust goes im kinda curious to see if it works or helps</TD></TR></TABLE>
That kind of exhaust will never help. What would pushing air into the exhaust do other than **** the o2 reading up?
Old Sep 30, 2004 | 12:08 PM
tgreaves's Avatar
Default Re: (Boltz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boltz &raquo;</TD></TR><TR><TD CLASS="quote">That has got to be the dumbest thing ive ever seen. Waste of wire, gas, and my time for clicking on, and now replying to this post. So why would you even waste your time? </TD></TR></TABLE>
laughter
n 1: the sound of laughing [syn: laugh] 2: the activity of laughing; the manifestation of joy or mirth of scorn; "he enjoyed the laughter of the crowd"
Old Sep 30, 2004 | 12:29 PM
INTEGRAGATED's Avatar
Are you missing the fact that the beetle's with that exhaust have the engine in the back??? Your making it harder for the motor to push the exhaust out at high speed, and all the fresh air that would be pushed in there would change the O2 reading.. good luck.
Old Sep 30, 2004 | 12:41 PM
philadd's Avatar
Default Re: Turbo GSR CRX (INTEGRAGATED)
READ PEOPLE... it was just for "***** and giggles", not a serious setup.
Old Sep 30, 2004 | 12:42 PM
liam821's Avatar
25 Year Member
Its gonna blow exhaust all over the front of the car and front window. Just aim it down like everybody else.
liam
