88 si tranny on a dohc ZC ??
Old Sep 30, 2004 | 07:25 AM
johnpowellcrx's Avatar
Default 88 si tranny on a dohc ZC ??
i just got a dohc ZC engine to go into my 88 crx si i need to get a new clutch and was wandering if the flywheel from the origanal D16 will fit on to the ZC can i just go buy a 21 spline clutch which would normally go in to the stock setup and are there any other things that i will need to watch out for in this swap? as far as i have read it is a direct bolt in no problem but it you know of any catches just tell me
Old Sep 30, 2004 | 08:35 AM
dr_latino999's Avatar
Default Re: 88 si tranny on a dohc ZC ?? (johnpowellcrx)
That's a good question, I have a been wondering the same thing.
Old Oct 4, 2004 | 02:39 PM
4potnick's Avatar
use your origanal cluth and tranny. Do yyou already have a ZC motor?
Old Oct 4, 2004 | 03:01 PM
ek_99_SiR's Avatar
Default Re: 88 si tranny on a dohc ZC ?? (4potnick)
i have a 91 si flywheel im sure the 88 would work
Old Oct 5, 2004 | 07:09 AM
4potnick's Avatar
Default Re: 88 si tranny on a dohc ZC ?? (1.6i-16zc)
As far as I know. You have to use same year flywheel and clutch. I had 88si tranny with 90 clutch and flywheel.
Old Oct 5, 2004 | 12:34 PM
Loaded Butane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick &raquo;</TD></TR><TR><TD CLASS="quote">As far as I know. You have to use same year flywheel and clutch. I had 88si tranny with 90 clutch and flywheel. </TD></TR></TABLE>
Are you sure that is what you had?
The 88 tranny input shaft has a different spline count than the 90 tranny so the clutch disc wouldnt work. You could use the 90-91 Flywheel, PP, and a 87 Prelude disc and that would work.
You can run your 88 flywheel, clutch, and tranny no problem on the ZC. Thats the setup I had when I first put the ZC in.
Old Oct 5, 2004 | 09:23 PM
4potnick's Avatar
Default Re: 88 si tranny on a dohc ZC ?? (Loaded Butane)
Maybe my tranny is a 89? I got it from a junkyard from a crx without door mounted seatbelts. thought it was 88, must be 89. I have heard about something different with 88's. My new name is Mr. bad info. LOL jk
MyRex
Oct 14, 2005 07:00 PM
smokinjs420
10
Nov 11, 2003 07:36 PM
giantdumbass
10
Oct 18, 2003 11:53 AM
FourthGenHatch
11
Apr 16, 2003 06:43 PM
crxnug
Dec 8, 2001 12:31 PM
