Thermal plastic around header's manifold pipes + CAI
Old Sep 29, 2004 | 10:57 PM
yeegsr's Avatar
Default Thermal plastic around header's manifold pipes + CAI
is it worth the time and money to but some thermal plastic or carbon fiber and wrap up the header manifold?
wat about cold air intake piping...i know you wont feel the performance different but is it worth a try at all?
Old Sep 29, 2004 | 11:10 PM
Combustion Contraption's Avatar
bump i have wondered this as well.
Old Sep 29, 2004 | 11:20 PM
yeegsr's Avatar
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">bump i have wondered this as well.</TD></TR></TABLE>
haha so bump, and bump...
i didn't some research about header gasket to the head..some gasket provides great insulator...the idea is to prevent heat get to header's manifold ...and this make sense man...
Old Sep 29, 2004 | 11:22 PM
yeegsr's Avatar
oh man where do you live...that AMC look like the block at SANTA ANA tell me man...so when i hit up ur 196 hp white hatch ...ill give you a thump up and back my azz back...lol
Old Sep 30, 2004 | 04:30 AM
Greenery18's Avatar
Default Re: (yeegsr)
Ok the header heat wrap is not to keep your engine bay cool, it is to keep the exhaust temperatures high. As exhaust cools, it loses velocity. So the wrap keeps the exhaust pulse velocity up, allowing exhaust to exit more freely.
Old Sep 30, 2004 | 10:48 AM
i am in so cali, but thats not the AMC. Id rather not specify where i live.
Old Sep 30, 2004 | 12:34 PM
H22coupe's Avatar
Default Re: (Greenery18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greenery18 &raquo;</TD></TR><TR><TD CLASS="quote">Ok the header heat wrap is not to keep your engine bay cool, it is to keep the exhaust temperatures high. As exhaust cools, it loses velocity. So the wrap keeps the exhaust pulse velocity up, allowing exhaust to exit more freely.</TD></TR></TABLE>
Actually wrapping the headers would help to keep down underhood temps as more heat kept in the exhaust is less heat dissipated to the underhood environment. As for the intake side of things, keeping the intake air cool helps create more power. The hondata intake mani gasket helps to keep the intake mani temp down so the mani does not tend to heat the intake air. Shielding/insulating the intake pipe from heat sources would also help keep the intake air cooler as would pulling intake air from a cooler source (i.e. AEM cold air intake or one of the intakes that box off the filter from the engine bay).
Old Sep 30, 2004 | 06:47 PM
yeegsr's Avatar
yeah i was reading somethign about this...and tempting to do so....exhaust pulse V...good info man thanx..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22coupe &raquo;</TD></TR><TR><TD CLASS="quote">
Actually wrapping the headers would help to keep down underhood temps as more heat kept in the exhaust is less heat dissipated to the underhood environment. As for the intake side of things, keeping the intake air cool helps create more power. The hondata intake mani gasket helps to keep the intake mani temp down so the mani does not tend to heat the intake air. Shielding/insulating the intake pipe from heat sources would also help keep the intake air cooler as would pulling intake air from a cooler source (i.e. AEM cold air intake or one of the intakes that box off the filter from the engine bay). </TD></TR></TABLE>
yeah i noticed but it didn't comes across me about underhood temps...thanx for your information....good stuffs
anyone acutally have the verified power gain to this project...
Old Sep 30, 2004 | 06:52 PM
yeegsr's Avatar
Default Re: Thermal plastic around header's manifold pipes + CAI (yeegsr)
by any change is there any good material of heat wrapp would someone want to recommend to use for header manifold....
AllMoToRB18c
Sep 28, 2008 01:03 PM
AllMoToRB18c
Northeast (Sales)
19
Sep 28, 2008 01:02 PM
spoon23_JDizM AkA SpOoN20
Mar 21, 2006 05:53 AM
bigwig
Nov 25, 2003 05:43 PM
Stu
May 31, 2003 07:58 AM
