SOCAL SHOP TO REMOVE STEERING WHEEL
Old Sep 29, 2004 | 09:46 PM
noho818's Avatar
Default SOCAL SHOP TO REMOVE STEERING WHEEL
WHAT OTHER TOOL OR IS THERE A SHOP WHERE I CAN GET IT DONE IN SOCAL
Old Sep 29, 2004 | 11:14 PM
threatcon13's Avatar
New User
Default Re: SOCAL SHOP TO REMOVE STEERING WHEEL (noho818)
all u need really is torx from what i remember
Old Sep 29, 2004 | 11:37 PM
Seedc2's Avatar
Default Re: SOCAL SHOP TO REMOVE STEERING WHEEL (Threatcon13)
torx 30 on each side of the steering wheel. that should pop the air bag unit off. (you have to pop misc. plastic peices off and unplug harnesses within the steering wheel.) Then use a 19mm to take the nut off holding the steering wheel.
EDIT: before you do this.. unplug your negative battery terminal.. wait about 20 minutes to be safe before pulling your steering wheel off
Old Sep 30, 2004 | 05:26 AM
MikeTV
Guest
Posts: n/a
Default Re: SOCAL SHOP TO REMOVE STEERING WHEEL (sim shadeee)
also, be sure to unplug your airbag first...it is the yellow connector under the steering wheel
Old Sep 30, 2004 | 02:15 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sim shadeee &raquo;</TD></TR><TR><TD CLASS="quote">torx 30 on each side of the steering wheel. that should pop the air bag unit off. (you have to pop misc. plastic peices off and unplug harnesses within the steering wheel.) Then use a 19mm to take the nut off holding the steering wheel.
EDIT: before you do this.. unplug your negative battery terminal.. wait about 20 minutes to be safe before pulling your steering wheel off </TD></TR></TABLE>
Helms says 10 mins. Save yourself 10 mins.
Old Sep 30, 2004 | 03:15 PM
TunerN00b's Avatar
Default Re: SOCAL SHOP TO REMOVE STEERING WHEEL (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Helms says 10 mins. Save yourself 10 mins.</TD></TR></TABLE>
With an airbag, I'll take the extra 10 minutes, but that might just be me.
crazyhouse2011
21
Apr 25, 2013 05:58 PM
civicDX2178
Jul 5, 2006 01:17 PM
krnboynemesis
Jul 14, 2005 09:44 AM
civicb16
12
Nov 10, 2004 04:23 PM
kikkoboyie
Sep 15, 2002 02:55 AM
