how hard or how much for a rear break conversion 89 civic HB
i was just wondering how hard it would be to do a conversion or if it was even possible. if so how much and where could i get one......drumb breaks suck!!!
Rear discs off of a 90'-91' Crx Si or DA integra will bolt directly on trailing arms and all. Check your local junkyards.
Yeah, easy swap and makes a world of difference. Try and get the integra or Si proportioning valve also this will help distribute more of the braking power to the rear.
Yeah, i forgot about that. Your car has the 40/30 prop valve. The integra/crx si have the 40/40 prop valve. You might wanna swap that also to increase your rear stopping power.
Easy. Just get the trailing arms from 90-93 teg or 90-91 CRX Si. I have pics from my swap if you need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2nd_gen_crx »</TD></TR><TR><TD CLASS="quote">Yeah, i forgot about that. Your car has the 40/30 prop valve. The integra/crx si have the 40/40 prop valve. You might wanna swap that also to increase your rear stopping power.</TD></TR></TABLE>
teg = 40/40
crx (90-91 Si) = 40/20
teg = 40/40
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">
teg = 40/40
crx (90-91 Si) = 40/20</TD></TR></TABLE>
Hold on, so the proportioning valves from the CRX w/rear-discs and the DA w/rear-discs are different?
teg = 40/40
use lots of PB blaster. Spray allt he bolts and let them sit before you even think about cracking them loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">
Hold on, so the proportioning valves from the CRX w/rear-discs and the DA w/rear-discs are different?</TD></TR></TABLE>
Yes. they work the same. but the difference is due to the larger calipers in the front of the DA's
crx w/ rear drums = 40/30
crx w/ rear discs = 40/20
teg = 40/40
teg = 40/40
I got a rear trailing arm assy from a 93 GSR. E-brake cables were intact and so were the rubber brake lines. Bolted up perfectly, set me back $116 plus shipping.
I got lucky on price however.
I also put SiR front knuckles hubs and brakes, with the SiR porportioning valve.
Very easy to do. I have a set here I will let you have everything for 125 plus shipping. Just email me or post back.
WAIT A MINUTE U GUYS
shoot let the guy breath before people try sellin u stuff u may not want/need whatever find out what u need....u have a Hatch therefore u need integra brakes and e brake lines attached not cut.....if u dont have the integra ebrake lines u will have no ebrake this is a bad thing......so make sure ur not getting crx rear discs....two u may want to change pads when u do this and maybe the trailing arm bushings they tend to break over time making for bad things to happen on the worst day.....so yeh look into buying integra brakes for ur car u can get ones that have abs just dont connect the abs lines ull be fine....and good luck check local junkyards ive gotten the stuff before for under 100 so try and find a u pull it place or whatever have fun...and get an alignment when ur done ur tires will thank u
Paypal or money orders are fine. Give me a morning to pull them off and get them ready to ship. These are off a 91 Integra LS and you will get everything even the bolts if they all will come out.
how would you do a rear disc break conversion for a 89 crx si? could i just bolt on the rear breaks from a 90 or 91 crx si or can i use the rear breaks from a integra?
pxsx
Jul 21, 2008 08:19 AM
bigstevo106
Sep 21, 2004 06:23 PM
VisualEcstasy
Mar 21, 2003 09:57 PM
