type R swaybar or aftermarket
Old Sep 29, 2004 | 08:36 PM
dohcroc's Avatar
Default type R swaybar or aftermarket
ive been trying to look into a rear sway bar for my DC but im not sure what to get ive read about all the people who are using the type r sway and all good thing have been said but i dont care to spend extra money on aftermarket sway if its goin to be better. it for a daily driver with tein ss coilover,front neuspeed 4point bar and neuspeed rear lower bar, and upper trunk bar with emracing pillar bar with 16" wheels if any of this can help u help me. thanx
Old Sep 29, 2004 | 08:48 PM
jdm_cars's Avatar
Default Re: type R swaybar or aftermarket (dohcroc)
aftermarket...
why get stock one... no need that ghey type ARRR....
I would get Cusco or something nice.
Old Sep 29, 2004 | 09:08 PM
allmotorteg_96's Avatar
Default Re: type R swaybar or aftermarket (jdm_cars)
i would go with a aftermarket one
Old Sep 29, 2004 | 09:17 PM
gsr-2nr's Avatar
Default Re: type R swaybar or aftermarket (allmotorteg_96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorteg_96 &raquo;</TD></TR><TR><TD CLASS="quote">i would go with a aftermarket one</TD></TR></TABLE>
me to i dont want to drill in my subframe putting a itr one on
Old Sep 29, 2004 | 09:21 PM
IntegraBoy04's Avatar
Default Re: type R swaybar or aftermarket (gsr-2nr)
I'd get the Comptech tie/sway combo. It has its own subframe reinforcement.
Old Sep 29, 2004 | 09:25 PM
LSvtec03's Avatar
Default Re: type R swaybar or aftermarket (IntegraBoy04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">I'd get the Comptech tie/sway combo.</TD></TR></TABLE>
me three
Old Sep 29, 2004 | 09:43 PM
timmy8151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_cars &raquo;</TD></TR><TR><TD CLASS="quote">aftermarket...
I would get Cusco or something nice.</TD></TR></TABLE>
The ITR sway bar is not "ghey" as you put it. If you do a search, you'd read that the ITR sway upgrade is one of the best valued mods you could do to your car. The ITR is a hefty bar at 22mm. A lot of aftermarket bars are only 19mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr-2nr &raquo;</TD></TR><TR><TD CLASS="quote">
me to i dont want to drill in my subframe putting a itr one on</TD></TR></TABLE>
Drilling the subframe is easy. It only took me an hour to install my ITR bar and BSQ kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">I'd get the Comptech tie/sway combo. It has its own subframe reinforcement.</TD></TR></TABLE>
The Comptech system is nice, but it also costs about $370. It only cost me a $120 (including BSQ kit) for the ITR sway system.
Old Sep 29, 2004 | 11:53 PM
SneezR's Avatar
lots of people had sucess with oem itr sway and bsq and or beaks kit. No need to spend more on aftermarket, only if you wish.
Old Sep 30, 2004 | 10:57 AM
dohcroc's Avatar
Default Re: type R swaybar or aftermarket (SneezR)
i dont mind spendin the money on aftermarket bar but if the type R will be a better bar for my car i will go with it
Old Sep 30, 2004 | 02:08 PM
Kapman38's Avatar
I just completed a ITR 22mm rear sway bar, with BSQ Kit. Took under an hour. Drilling was no problem, I had a rear tie bar and 12mm stock LS ,and the new 22mm is so much better then both rear tie and 12mm, Now front does not plow at all. Rear is so stiff it is not funny. But I also have ITR trunk bar and JDM ITR rear strut bar. (So could add to stiffness. ) It cost me under $135 shipped for BSQ and full ITR kit. BSQ website has all info. Got parts from Acuracarland, of Atlanta, great prices... Len is a good source as well. I would go with OEM Honda, can not go wrong..
Kapman
Old Sep 30, 2004 | 02:28 PM
xprohx's Avatar
I think too much
Default Re: type R swaybar or aftermarket (Kapman38)
Personally I'm going to get the itr sway bar/bsq kit. It is a bang for the buck suspension mod that gives results like everyone says. I say save your money and go with oem sway bar.
Anyone have pics of the welded nut your supposed to nock out?
Old Sep 30, 2004 | 02:37 PM
artifex's Avatar
say it
Default Re: type R swaybar or aftermarket (xprohx)
its pretty obvious when you get the control arm out of the way and try to fit the backing plate of the mount kit.
Old Sep 30, 2004 | 02:53 PM
tegon-gsr's Avatar
Default Re: type R swaybar or aftermarket (artifex)
true i got got one and it is like night and day driving from stock gsr sway bar to type r sway bar.
Old Sep 30, 2004 | 02:58 PM
wesb18c's Avatar
Yeah, probably your best bet.
Old Sep 30, 2004 | 04:02 PM
DB8_TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezR &raquo;</TD></TR><TR><TD CLASS="quote">lots of people had sucess with oem itr sway and bsq and or beaks kit. No need to spend more on aftermarket, only if you wish.</TD></TR></TABLE>
Old Sep 30, 2004 | 05:13 PM
dohcroc's Avatar
Default Re: type R swaybar or aftermarket (DB8_TEG)
i was lookm at the comptech but i have rear lower tie and the comptech comes with one already is there anyother aftermarket that is good or are they just as equal to the type R
Old Oct 1, 2004 | 08:16 AM
integra15's Avatar
ITR sway is the best for the money, and you only have to drill 2 small holes to install it, no big deal.
Old Oct 1, 2004 | 08:18 AM
B18Flip's Avatar
Default Re: type R swaybar or aftermarket (integra15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra15 &raquo;</TD></TR><TR><TD CLASS="quote">ITR sway is the best for the money, and you only have to drill 2 small holes to install it, no big deal.</TD></TR></TABLE>
plus its just as thick (22mm) or thicker than most aftermarket bars.
Old Oct 1, 2004 | 08:44 AM
GsrGilbert's Avatar
Default Re: type R swaybar or aftermarket (B18Flip)
ive got the comptech sway/tie combo and i absolutly love it
Old Oct 1, 2004 | 10:39 AM
uLTrAvTEc757's Avatar
Default Re: type R swaybar or aftermarket (GsrGilbert)
anyone running a progress rear sway bar? i know they are pretty inexpensive....are they junk? is it going to rip off of the subframe?
Old Oct 1, 2004 | 10:59 AM
timmy8151's Avatar
Default Re: type R swaybar or aftermarket (uLTrAvTEc757)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uLTrAvTEc757 &raquo;</TD></TR><TR><TD CLASS="quote">anyone running a progress rear sway bar? i know they are pretty inexpensive....are they junk? is it going to rip off of the subframe?</TD></TR></TABLE>
IIRC, the progress rear sway bar is non-adjustable and 22mm in diamter. I believe it costs about $190 for the kit. For about $130 you can get yourself the ITR sway with the BSQ kit, and it should provide that same performance.
Old Oct 1, 2004 | 12:29 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Does anyone have a pair of stock 'Teg end links for sale for cheap?
Please email me at garylee333@yahoo.com
Thanks!
Old Oct 1, 2004 | 12:36 PM
dFreezy's Avatar
Default Re: type R swaybar or aftermarket (Gee3)
oem itr sway bar all the way...best $120 i spent on my car
Old Oct 1, 2004 | 01:42 PM
RedGSR's Avatar
How does the progressive rear sway bar look like? It seems like the RSX one has the reenforcement to the subframe. But I can't find any picture for the Integra one.
Old Oct 1, 2004 | 02:21 PM
96ls's Avatar
Default Re: (RedGSR)
i have the suspension techniques kit on my 96 ls 4 door, and absolutely love it. the kit was only like 230 for front and rear.
