oil pan gasket
Old Dec 12, 2001 | 07:20 PM
ILOVEGIRLS's Avatar
Default oil pan gasket
what gasket should i get and does anyone know if i need to torque then down? thanks
Old Dec 12, 2001 | 10:59 PM
GTEater's Avatar
Default Re: oil pan gasket (ILOVEGIRLS)
stock honda gasket w/ honda bond and there is a specifc pattern to bolt them down......30 ft/lbs total
Old Dec 12, 2001 | 11:14 PM
da6vtec's Avatar
Default Re: oil pan gasket (GTEater)
dude if you torque them to 30 lbs they'll break off! 8 lbs. is the torque spec for the oil pan bolts.
Old Dec 13, 2001 | 12:39 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: oil pan gasket (da6vtec)
If I remember correctly its 9ft/lbs or 12 Nm. 30ft/lb will break the studs right off.
art
Old Dec 13, 2001 | 11:27 PM
ILOVEGIRLS's Avatar
Default Re: oil pan gasket (Arturbo)
thanks guys..is there also a sequence to do them?
Old Dec 13, 2001 | 11:51 PM
Chris's Avatar
I say go in a circle.......... I did with no problems.
it is 9 ft pounds.
Old Dec 14, 2001 | 07:44 AM
96IntegraLS4DR's Avatar
Don't have manual w/ me but IIRC start from middle and alternate across
the pan.
Example: 1.3.5.7.9->
<-8.6.4.2
Old Dec 17, 2001 | 12:35 AM
ILOVEGIRLS's Avatar
Default Re: oil pan gasket (96IntegraLS4DR)
thanks again!!
Old Dec 17, 2001 | 09:20 AM
GTEater's Avatar
Oops your right.........just rebuilt the engine a couple of weeks ago and I still got a bunch of numbers floating in my head........it is 8 ft/lbs
Old Dec 17, 2001 | 09:53 AM
IMPATIENT's Avatar
do not torque the bolts to 30 lbs, the gasket and the bolts will be ruined if you torque them, just tighten the bolts with a drive wrench until there snug and the gasket is secured firmly, cross pattern is the way..........
slowexcoupe
Nov 10, 2013 01:18 PM
hYbRid_Eg6
Feb 12, 2012 06:14 PM
93delsoldrew
Jun 22, 2008 09:38 AM
Rhood
Feb 7, 2007 05:30 PM
iheartintegras
Jan 21, 2007 12:42 PM
