Kenji ECU question
Old Sep 29, 2004 | 05:30 PM
emissionsux's Avatar
Default Kenji ECU question
I want to hook up my wideband to my car just to see my AFR, but I don;t have a secondary O2 bung yet. My question is if the Kenji progran runs closed loop, would the readings be thrown off ot throw a code if I left my O2 hanging while I put the wideband O2 in the bung?
Old Sep 30, 2004 | 05:44 AM
Default Re: Kenji ECU question (emissionsux)
Anyone?
Old Sep 30, 2004 | 06:00 AM
b19coupe's Avatar
If the program runs in closed loop, it will code. It will also throw off the A/F a bit as the ECU will not be able to use the 02 sensor output to fine tune the mixture. You should be able to get a rough idea of where the A/F is though.
Old Sep 30, 2004 | 06:21 AM
Default Re: Kenji ECU question (b19coupe)
Thanks.......I've been wanting to check my AFR because I have a feeling I am running extremely rich with this program.
Old Sep 30, 2004 | 07:36 AM
R-Toyz.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emissionsux &raquo;</TD></TR><TR><TD CLASS="quote">Thanks.......I've been wanting to check my AFR because I have a feeling I am running extremely rich with this program.</TD></TR></TABLE>
You are running rich
Old Sep 30, 2004 | 08:04 AM
Default Re: Kenji ECU question (rtzcom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtzcom &raquo;</TD></TR><TR><TD CLASS="quote">
You are running rich </TD></TR></TABLE>
Yup, I know I'm running rich, I just want to know how bad the numbers.
Shonn
Oct 16, 2006 04:29 AM
Touge Tuning
Aug 29, 2005 10:56 AM
520_Motorsports
Aug 10, 2004 10:51 AM
shadowstylz
22
Sep 19, 2003 09:29 AM
GumballNA
Jul 5, 2003 08:12 AM
