Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
New Suspension Question
Old Sep 29, 2004 | 04:02 PM
EM1VtecSi's Avatar
Default New Suspension Question
Hey I just got my new Omni Coilovers(Street), and was wondering if i should get a rear sway bar also, or would i have to get both front and rear. Also, i need new tires, and can't decide between Falken Azenis or Kuhmo Ecsta 100's. Any adivce, thx.
Old Sep 29, 2004 | 04:03 PM
Drew M's Avatar
New User
Default Re: New Suspension Question (EM1VtecSi)
What are you doing with the car?
1. Autocross
2. HPDE
3. Road Racing
4. cAnYoN kArViNg y0!
5. Boulevard Pimping
6. Blingin' in the mall parking lot
7. Street racing
8. Daily driving trying to be tite
9. Drag racing
Choose all that apply but list them in order from "most frequent" to "least frequent".
Old Sep 29, 2004 | 04:10 PM
EM1VtecSi's Avatar
Default Re: New Suspension Question (Evil Drew M)
Daily Driven, Occosianal track use, <--- drives very aggresively through corners, and etc. etc.
Old Sep 29, 2004 | 04:15 PM
.RJ's Avatar
.RJ
First off, this is not a new question ----> https://honda-tech.com/zerosearch and select archived topics. Set aside and hour or three and do some reading.
And also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1VtecSi &raquo;</TD></TR><TR><TD CLASS="quote">]Occosianal track use, &lt;--- drives very aggresively through corners, and etc. etc.</TD></TR></TABLE>
Driving aggressively is NOT track use!!!!!! It is street jackassery.
Read the forum FAQ. Look at the guidelines and you will notice this forum is not a 'catch-all' for suspension/tire topics. Then look at all the links in the post and read through them.
:lock:
Drew M's Avatar
New User
So your list would be:
Sway bars effectively increase your spring rate. The street kit is 300-400lb range springs IIRC which is probably enough for what you do. If you want to do a rear bar go for it but nothing radical (no more than an ITR or equivalent) or you will find yourself blingin' sideways into telephone poles in the rain since you drive "very aggresively through corners".
Understeer is safe. The more rear rate you have the more oversteer you achieve.
Plus - the ladieZ will never see the swaybarZ under your car so they won't be turned on by them.
As for tires - Neither Azenis or the Kumhos are worth a **** for drifting so stay away from both.
maxogsr
29
Dec 22, 2011 06:07 AM
Tyson
Suspension & Brakes
Mar 30, 2007 03:48 PM
nvmyb20hatch
Suspension & Brakes
Jun 19, 2005 03:32 AM
WH0R3nEF9
Apr 23, 2005 12:19 PM
520_Motorsports
Aug 27, 2004 08:10 PM
