B16 tranny seal
Old Sep 29, 2004 | 03:58 PM
B16 ED9's Avatar
Default Please help ASAP
I have a OBD 0 B16A motor along with the tranny, When my friend and I were replacing the axels 90-93 integra axels, I think we might of damaged the seal that is on the tranny where the axel goes into, I need to replace the seal, which year seal would I need to use? 90-93 integra? or is it something else, please help me. Thank you in advance
Old Sep 29, 2004 | 04:45 PM
B16 ED9's Avatar
Default Re: Please help ASAP (B16 EF)
anyone?
Old Sep 29, 2004 | 04:55 PM
kur0ryu's Avatar
90-93 LS integra seals will do fine
Old Sep 29, 2004 | 06:42 PM
B20 CRX SI's Avatar
Default Re: Please help ASAP (kur0ryu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kur0ryu &raquo;</TD></TR><TR><TD CLASS="quote">90-93 LS integra seals will do fine</TD></TR></TABLE>
Can someone back this up? Iam having the same problem
Old Sep 29, 2004 | 07:33 PM
kur0ryu's Avatar
Default Re: Please help ASAP (B20 CRX SI)
90-93 LS trannys are B series cable trannys, I just bought new seals 2 weeks ago for my J1 tranny at the acura dealership and that's what I asked for.
Old Sep 29, 2004 | 07:36 PM
B20 CRX SI's Avatar
How about 92 GSR 1.7 seals, will those work as well?
Old Sep 29, 2004 | 07:39 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20 CRX SI &raquo;</TD></TR><TR><TD CLASS="quote">How about 92 GSR 1.7 seals, will those work as well?</TD></TR></TABLE>
If ppl say the LS ones work fine, y even ask this question? But to answer your question anyway, they should also work fine. There is a specific LEFT and RIGHT side seal, so they both arent the same.
Old Sep 29, 2004 | 07:43 PM
B20 CRX SI's Avatar
Default Re: Please help ASAP (fourthgenhatchB17)
No disrespect towards kur0ryu, I really appriciate his reply, the reason why I asked is because couple of people told me some different ones that's why I asked I was double checking before I go and buy it
Old Sep 29, 2004 | 09:03 PM
turbo_ef9's Avatar
would a bad seal cause the tranny to leak from that specific spot?? mine leaks and it seems from there.. and how would u fix it?
Old Sep 29, 2004 | 09:12 PM
Malgerus's Avatar
Default Re: Please help ASAP (eli_vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang &raquo;</TD></TR><TR><TD CLASS="quote">would a bad seal cause the tranny to leak from that specific spot?? mine leaks and it seems from there.. and how would u fix it?</TD></TR></TABLE>
Yes.
You carefully pry the old seal out, (mine was a biznitch to get out, so I wasn't all that careful), clean the surface, and get a big socket so you can tap in the seal evenly. I actually used a 2.5 inch piece of exhaust piping and some tape to tap it in. Worked for me, no more leaks
Old Sep 30, 2004 | 08:55 AM
turbo_ef9's Avatar
Default Re: Please help ASAP (Mr. S)
how much do the seals cost?
Old Sep 30, 2004 | 09:42 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang &raquo;</TD></TR><TR><TD CLASS="quote">how much do the seals cost? </TD></TR></TABLE>
I replaced a passenger side seal for my JDM YS1 with a 92 GSR seal and it was like 5 bucks or so OEM I think. My passenger axle was leaking right where it goes in to the tranny. replaced the seal and all has been well since.
Old Sep 30, 2004 | 10:48 AM
B16 ED9's Avatar
Default Re: Please help ASAP (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">
I replaced a passenger side seal for my JDM YS1 with a 92 GSR seal and it was like 5 bucks or so OEM I think. My passenger axle was leaking right where it goes in to the tranny. replaced the seal and all has been well since. </TD></TR></TABLE>
Same problem Iam having
philliedawg
Jul 20, 2008 05:35 AM
hondateg10
Jul 22, 2007 10:19 PM
crxsirvtec
Apr 18, 2004 06:03 AM
DavidTurbo
Mar 26, 2003 03:02 PM
kshymkiw
20
Oct 22, 2002 06:38 AM
