Where is your ECU?
Old Sep 29, 2004 | 02:44 PM
Audi RS4's Avatar
Lover
Default Where is your ECU?
I'm looking to move my ECU for roll cage purposes and was wonder where everyone moved theres to and how they went about mounting them (brackets, mounting hardware), i just want some fabrication ideas!!
pictures would be great.
Old Sep 30, 2004 | 06:27 AM
McDade's Avatar
Default Re: Where is your ECU? (AK1200)
i moved my ecu higher because people kept stomping on it when i hit my brakes.
(stock mounting point is under a plate at the feet of the passenger)
does using a steel bar + bolts = fab?
Old Sep 30, 2004 | 07:41 AM
kb58's Avatar
Banned
Default Re: Where is your ECU? (McDade)
Behind the passenger seat on the floor, with a break-out of every signal for easy testing and modification. It's an H22A1 drive-train. (You didn't specify what car )
Old Sep 30, 2004 | 08:12 AM
mchuang's Avatar
You need to make that wiring a lil neater IMO
Old Sep 30, 2004 | 08:46 AM
kb58's Avatar
Banned
Default Re: Where is your ECU? (mchuang)
Hah! That's just thrown in. Wait until it all starts going back together, THEN you'll see nice wiring. I'm still stringing new ones...
Old Oct 1, 2004 | 06:16 AM
Dee's Avatar
Dee
Default Re: Where is your ECU? (kb58)
Mounted in the glove box because the new cage blocks the stock spot.
Old Oct 1, 2004 | 09:28 AM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">Hah! That's just thrown in. Wait until it all starts going back together, THEN you'll see nice wiring. I'm still stringing new ones...</TD></TR></TABLE>
I think he was referring to the mess of wiring above yours.
Old Oct 1, 2004 | 11:33 AM
McDade's Avatar
Default Re: Where is your ECU? (High and Dry)
bah!
you should have seen my wiring before i moved it up there
Old Oct 1, 2004 | 02:55 PM
S9i1R's Avatar
Damn I need to do something like that ^^^. I've been trying to put a P28 in the stock spot for a PM6 or whatever the '91 Si's have. I'm using two .125" strips of Al as mounting strips. If it doesn't work out I'll look at putting it where the glovebox was.
DAMN THEIVES
Nice work guys .
Old Oct 1, 2004 | 08:19 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by McDade &raquo;</TD></TR><TR><TD CLASS="quote">bah!
you should have seen my wiring before i moved it up there</TD></TR></TABLE>
At least they're all soldered. I can live with that.
I've seen cars with alligator clips meant for testing running from the passenger compartment to the battery....
Wytek9
Engine Management and Tuning
Apr 19, 2009 02:38 PM
rolledthatho
Aug 11, 2005 11:17 PM
revtech motorsports
Mar 23, 2005 03:50 PM
vbspec
Apr 8, 2004 03:56 PM
95integra_gsr
Dec 18, 2001 03:18 PM
