DISAPPOINTED with 1/4 times!!
Old Sep 29, 2004 | 01:03 PM
Death_to_Thieves's Avatar
Default DISAPPOINTED with 1/4 times!!
hey whats up guys I took my car to the track the for the 1st time on 9/25 at Maple Grove Race way for the IDRC event going on. I thought the event really sucked but it was a good opportunity to run my car for the first time and get some experience at the track. I ran a best of 15.5 with a 2.5 60 ft and 92 mph speed. My setup is as follows, 92 GSR with full weight, 2700lbs with me in it. I have a JDM integra type R head complete with cams, ITR intake manifold, CTR bored throttle body. .25 OS CTR pistons in B17a. CTR intake cam, CTR crank pulley. an ECU that is supposed to be JUN spec that I got off Ebay. a ACT clutch with 4 puck, DC headers, AEM CAI. S1 tranny. Some garbage street tires that were at 32 psi. I didnt even know that I would be able to race. I just went to watch and I was told I didnt need a helmet but I would have to pass a tech inspection. I passed and decided to race. I thought I would do alot better but left very disappointed. Car has also never been tuned. Is it me or does this suck?? in everyones opinion, what times you think I should be doing ? any help, criticism and tips are always appreciated. Thanks guys
Old Sep 29, 2004 | 01:26 PM
Veris's Avatar
Default Re: DISAPPOINTED with 1/4 times!! (8000KReV)
Your mph is about dead on for your weight & hp. IE ~165whp.
Your 60ft is killing your ET. Drop it to 2.2 or 2.3 and you'll run 14.9-15.2.
Most people running really fast times are running lightened chassis with race weights (including driver) of 2200lbs or less. A 2200lb race weight with 165whp will run in the mid to high 13's.
Old Sep 29, 2004 | 01:51 PM
el arbi's Avatar
Default Re: DISAPPOINTED with 1/4 times!! (Veris)
He's right, work on your 60ft
Old Sep 29, 2004 | 02:28 PM
Default Re: DISAPPOINTED with 1/4 times!! (99SiRacer)
I was launching at 4k with not so bad wheel spin. I think those crappy tires were killing me. PLus I dont have my YS1 any more and I am dealing with gears that are not as short. So you guys think this is an ok time for my setup? Im sure I can maybe go down a bit with some good tuning. My car is not tuned at all
Old Sep 29, 2004 | 02:38 PM
what do you think I can get my times down to? what are some good street tires? and what else should I do to improve?
Old Sep 29, 2004 | 04:56 PM
Old Sep 29, 2004 | 05:03 PM
Audi RS4's Avatar
Lover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99SiRacer &raquo;</TD></TR><TR><TD CLASS="quote">He's right, work on your 60ft </TD></TR></TABLE>
second that
Old Sep 29, 2004 | 05:24 PM
hondaguyef's Avatar
Default Re: DISAPPOINTED with 1/4 times!! (AK1200)
Falken Azenis for the street
Slicks ONLY for the track.
If you can get that 60' down to 1.9-2.0(on slicks) you will have yourself a low 14 sec. car. Get the slicks and you will never want to run street tires again. Trust me my bone stock b18b runs 14.50's
Phil
Old Sep 29, 2004 | 08:27 PM
mugeneghatchie's Avatar
race the car like you stole it you will run better but you might blow someting up ! it helps some times. did you launch ? and did you have slicks?
Old Sep 30, 2004 | 03:54 AM
Default Re: DISAPPOINTED with 1/4 times!! (mugencrx 250)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencrx 250 &raquo;</TD></TR><TR><TD CLASS="quote">race the car like you stole it you will run better but you might blow someting up ! it helps some times. did you launch ? and did you have slicks?
I raced on street tires at full psi. When I buy slicks what size do I need to get? and do they come with rims as well or are those purchased seperately?
Old Sep 30, 2004 | 09:29 AM
Veris's Avatar
22 or 23 inch.
I suggest MT 22x8x15. They run about 140 usd per tire. You'll need rims.
When running street tires drop your pressure to ~28psi. A good 60ft time on street tires is 2.2-2.3 as per my first message.
Good luck.
Old Sep 30, 2004 | 12:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Veris &raquo;</TD></TR><TR><TD CLASS="quote">22 or 23 inch.
Good luck. </TD></TR></TABLE>
where can I buy slicks? where could I get the rims? My car is lowered, will this cause issues? ii is lowered 2 1/4 in. on skunk 2 drop springs
Old Sep 30, 2004 | 12:20 PM
mmuller's Avatar
Mad Scientist
yeah, you should defenetely try lowering your 60's
but i still think trapping at 92 is low
Old Sep 30, 2004 | 12:50 PM
Default Re: DISAPPOINTED with 1/4 times!! (mmuller)
what do you thik my trap speed should be?
Old Sep 30, 2004 | 12:54 PM
Old Sep 30, 2004 | 02:15 PM
Veris's Avatar
Default Re: (8000KReV)
Your trap is fine for your weight and hp. 15.5 is ussually 88-89 mph.
For the rest; slicks and rims do some research. Or send me a cheque for my time.
Old Sep 30, 2004 | 03:40 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (Veris)
bring the 60 ft down the times will drop basic rule of thumb ever .1 you shve off your 60 ft is worth approx .2 on the big end ex: 14.5 w/2.5 60 ft = 2.2 60ft 13.9-14.0
Old Sep 30, 2004 | 04:56 PM
ICeDoUt's Avatar
Default Re: (HOOKUPS)
i was at that event, by far the worst show up out of any event i've been too. But it was a great day to run your car. I got 14 runs in plus the first round which i lost, red light! i saw you hangin out around your car towards the end of the day i had a turbo PY rex, u were prolly talkin to a friend of mine that went with me to the event, chad. but yea anyway i was also dissappointed with my times.
Old Sep 30, 2004 | 05:36 PM
EK22snatch
Guest
Posts: n/a
Default Re: (ICeDoUt)
honestly, hardly anyone gets great times the first couple times they take their car to the track. i mean, if you did then what else would there be to do?
dont be discouraged man, just practive and get your 60' better like alot of other ppl are saying - thats crucial.
Old Oct 12, 2004 | 05:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt &raquo;</TD></TR><TR><TD CLASS="quote">i was at that event, by far the worst show up out of any event i've been too. But it was a great day to run your car. I got 14 runs in plus the first round which i lost, red light! i saw you hangin out around your car towards the end of the day i had a turbo PY rex, u were prolly talkin to a friend of mine that went with me to the event, chad. but yea anyway i was also dissappointed with my times. </TD></TR></TABLE>
oh **** I did see you at the event. Yeah I was talking to your friend with the turbo LS VTEC eg right? Those were some nice cars you guys had. what was your times? your friend ran a 12.5 right?
Old Oct 12, 2004 | 02:53 PM
ICeDoUt's Avatar
yea he ran something like that he gets better times as we go to more events, i know he got better then that but i forget exactly what he got.
Death_to_Thieves
18
Sep 30, 2004 10:45 AM
DA Teg D00D
14
Feb 2, 2004 04:27 PM
Hondasaurs
Jul 2, 2003 07:17 PM
DutchITR1689
Jan 5, 2002 05:06 PM
