Honda S2000 Honda S2000
DRAG Turbo Impressions
Old Dec 12, 2001 | 05:29 PM
westcoaststyle's Avatar
Default DRAG Turbo Impressions
DRAG is going to be releasing a liquid cooled twin turbo set up for the NSX in Jan/Feb of next year. It will give an extra 100 hp to the flywheel and 80 hp to the wheels at a mere 3-5psi of boost (good for daily driving).
The kit will cost from $8000 to $9000 (most likely).
What are your guys' thoughts on the kit? I'd like to get your impressions.
Thanks!
Old Dec 12, 2001 | 08:17 PM
grippgoat's Avatar
Default Re: DRAG Turbo Impressions (westcoaststyle)
Don't see any compelling reason to get that over the basch boost kit. At least not without knowing a lot more details.
-Mike
Old Dec 13, 2001 | 09:49 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: DRAG Turbo Impressions (grippgoat)
just get a $500 NOS kit. 100 ponies isn`t jack and it won`t have a CARB number.
Ryan
Old Dec 13, 2001 | 10:22 AM
grippgoat's Avatar
Default Re: DRAG Turbo Impressions (vtecvoodoo)
Actually, last I heard, Mark Basch had decided he was going to do CARB certification for his kit.
-Mike
Old Dec 13, 2001 | 10:28 AM
vtecvoodoo's Avatar
Future Texas Boy
Deciding and getting are two different things. It`s not very cheap or easy.
Is Basch in SoCal or Arizona (just wondering)?
Ryan
Old Dec 14, 2001 | 10:43 AM
Muckman's Avatar
Moderator in Chief
Default Re: Questions: (FastNSX)
If I were to pay almost 10k for a turbo setup... id be damn sure to be pushing alot more than 3-5psi.... That doesnt sound right for a twin turbo setup.. too low?
Old Dec 14, 2001 | 03:59 PM
grippgoat's Avatar
I'm sure it'll meet the emissions requirements. But you're right, he hasn't got it yet, but then again his kit isn't final yet, either.
His original shop is in Phoenix. But he and Dali Racing I guess have another shop in SoCal that Basch can do work out of, or something. I don't really understand all the details.
-Mike
Old Dec 17, 2001 | 02:55 PM
bb6h22a's Avatar
Default Basch..
..has a shop here in Escondido, and his original shop in Pheonix. Personally, if I were to go F/I on an NSX, I would opt for the Basch kit, having read through the beta testing, Basch's own admitions to problems with the kit, dyno results, 1 year warranty, free install, and CARB certification it appears to me that this kit is well thought out, and well implemented.
Also, I think that the CARB certification will go forward, not only b/c of the commitment already made by Basch in developing and testing the kit, but all b/c of the customers that Basch caters to, and the degree of service that he has offered to his customers in the past.
[Modified by bb6h22a, 5:01 PM 12/17/2001]
Old Dec 20, 2001 | 02:20 PM
demonderrick's Avatar
well, as I know, Comptech SC is avaliable for a long time, it run 6 or 9 psi for the SC, and it gives 100 hps +, I wouldn't wanna go for the twin-turbo for only 100 hps.. I will still go for the SC, but, yes, the SC is 10K...
and no, I don't own a NSX..
Old Dec 24, 2001 | 07:05 PM
quikrpm'z's Avatar
Thats my mechanic didnt know he was so well known around this board.
Old Dec 26, 2001 | 01:26 PM
Greyout's Avatar
Default Re: DRAG Turbo Impressions (quikrpm)
there is a guy here in austin TX with a silver NSX w/ the comtech body kit, bult motor, and custom turbo kit. he puts down over 640 whp - and thats with aftermarket N/A cams and no cam gears.
Old Dec 26, 2001 | 11:22 PM
Spayellows2k's Avatar
Default Re: DRAG Turbo Impressions (JDM LUDE)
I know who you mean, last I hear he had 508 at the wheels. What has he done to get it to 640?
Old Dec 28, 2001 | 10:52 AM
Ok, the 508 number is on pump gas at 18 psi whereas at 24 psi on race gas and spray he's pushing 640.
Old Jan 1, 2002 | 05:28 PM
todaysivxx's Avatar
Default Re: Questions: (Muckman)
stupid ***...becuz of the high compression rate you cant boost that high...and NSX is already fast...with the turbo kit....you would probably run the mid 12s.....thts pretty damn fast.....wish i had one....then i would get one....DRAG turbo kits are bomb too....wont **** up the engine.....reliable.....plus you could always do more to the turbo.....but you will have to modify the internals.....valvs....pistons....buillshit like that ....otherwise dont think its just an expensive, shitty turbo kit youre buying.
Old Jan 2, 2002 | 05:21 PM
gsr camel's Avatar
- What turbos will the kit use?
- what is the max hp the kit can produce at full boost?
- where do the turbos go?
- where does the radiator for the IC go?
think about what u type b4 u ask it
cheers
confucius
Jun 6, 2005 06:19 PM
turbo Si
Aug 19, 2002 03:59 PM
integra-modder
Jul 11, 2002 09:36 AM
SwiftTypeR
Apr 27, 2002 05:02 AM
TaboR
Mar 3, 2002 09:31 PM
