My Teg's MPG is decreasing.
Old Sep 29, 2004 | 05:35 AM
integraguy2001's Avatar
Default My Teg's MPG is decreasing.
What could be the reason? need spark plugs? I'ven't change fuel filter since i got the car, it's now got 90k miles on it.
Old Sep 29, 2004 | 05:38 AM
iixerOii's Avatar
Default Re: My Teg's MPG is decreasing. (integraguy2001)
Well how many miles per full tank are you getting?
90K might be time for a tune up, spark plugs + wires, fuel filter, distributor cap, rotor.
Old Sep 29, 2004 | 06:06 AM
94ls's Avatar
Default Re: My Teg's MPG is decreasing. (iixerOii)
agree...time for a tune up at the 90k interval... time belt/water pump/tensioner also....... my 94ls w/ 85kmi on her gets about 250 mi/tank (mostly) city driving and some hwy driving. if i dont get on it and drive normal, then im up to about 280mi/tank all with 89octane. im bout to do all the major tune up stuff rather shortly. i def advise of it as well.
Old Sep 29, 2004 | 09:13 AM
Default Re: My Teg's MPG is decreasing. (94ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94ls &raquo;</TD></TR><TR><TD CLASS="quote">agree...time for a tune up at the 90k interval... time belt/water pump/tensioner also....... my 94ls w/ 85kmi on her gets about 250 mi/tank (mostly) city driving and some hwy driving. if i dont get on it and drive normal, then im up to about 280mi/tank all with 89octane. im bout to do all the major tune up stuff rather shortly. i def advise of it as well.</TD></TR></TABLE>
How big are teg tanks? I get about 220 miles if I fill all the way up... til the low gas light comes on
Can you guys list the things I need to change?
Old Sep 29, 2004 | 10:12 AM
Liquidgsr's Avatar
i have 130K+ on my car and i got last about 280 to the tank with 93. I am trying 89 this tank to see what that yields. Mostly city driving, some highway.
Old Sep 29, 2004 | 11:15 AM
iixerOii's Avatar
Default Re: My Teg's MPG is decreasing. (Liquidgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraguy2001 &raquo;</TD></TR><TR><TD CLASS="quote">
Teg tanks are 13.2 gallons. 220 for a full tank is about what I get mostly city driving. While I was driving to Baltimore MD the other day my HW mileage was great was like 150 per half tank.
Old Sep 29, 2004 | 11:19 AM
DynastyRacer22's Avatar
my car does it too..when im driven from here to about lets say 30miles away..it takes up at least half a tank..my 97 ls has 120k on it and maybe do you guys think i should change Fuel filter also? and how much would it cost thanks
Old Sep 29, 2004 | 11:31 AM
confucius's Avatar
Default Re: My Teg's MPG is decreasing. (DynastyRacer22)
Independent honda/acura told me to get a new O2 Sensor.
He told me to replace the one that is closes to your engine, since 96+ have two O2 sensor.
I have yet to get one and see if it would help.
O2 are expensive.
Old Sep 29, 2004 | 11:35 AM
blacknbean's Avatar
Default Re: My Teg's MPG is decreasing. (confucius)
i usually put in around 10 gallons on fillup and i get 250/260 out of that..so 280 isnt bad..but then again i race thru the gears everyday like no other
Old Sep 29, 2004 | 12:13 PM
sl33pyelmo's Avatar
on my 98 gsr, a full tank get me roughly 270 mile on a full tank with 18s wheels on..till i have to fill up again
Old Sep 30, 2004 | 04:44 AM
Default Re: My Teg's MPG is decreasing. (sl33pyelmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sl33pyelmo &raquo;</TD></TR><TR><TD CLASS="quote">on my 98 gsr, a full tank get me roughly 270 mile on a full tank with 18s wheels on..till i have to fill up again</TD></TR></TABLE>
Then something is def wrong, GSR suppose to eat more gas since it has vtec..
My engine light came on couple weeks ago, (never came on again) I checkt he ecu, it's code #71... cylinder 1 misfired... So far i haven't done anything to it yet.. I think I am getting new spark plugs this weekend and might as well get new fuel filters at the shop.
Car still runs smooth than ever... (i love integras)
Old Sep 30, 2004 | 05:11 AM
Pawwalski's Avatar
I usually get ~31 mpg... About 340+ miles per tank...
Pretty much stock 96 LS
Old Sep 30, 2004 | 06:11 AM
civic91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraguy2001 &raquo;</TD></TR><TR><TD CLASS="quote">What could be the reason? need spark plugs? I'ven't change fuel filter since i got the car, it's now got 90k miles on it.
I normally get 320/full tank. mostly city driving and some highway.
Old Sep 30, 2004 | 06:39 AM
gsr_to_the_MAX's Avatar
Default Re: My Teg's MPG is decreasing. (civic91)
i have a 98 gsr and i get 230 to around 8-8.5 gallons and its consistent because my gas gauge is broken so i fill up every 230ish and it take 8-8.5 to fill up. mainly highway.
Old Sep 30, 2004 | 07:31 AM
2005 TSX's Avatar
Default integraguy2001
Then something is def wrong, GSR suppose to eat more gas since it has vtec...</TD></TR></TABLE>
Not exactly true. A GS-R will only use more gas if the <U>driver</U> is pushing the car (flooring it) excessively.
With my car, a 2001 2-door GS-R with 52,000 miles, I can get about 36 or 37 m.p.g.
Things to help your gas mileage.
1. Check your spark plugs. Replace if needed.
2. Check your air filter. Replace if needed.
3. Check your fuel filter. Replace if needed.
4. Probably a good time to replace your timing belt.
5. Try driving in the highest gear as possible with out lugging your engine. Example...if you are driving in 4th gear, try driving the car in 5th.
6. Don't floor it everywhere you go...shift around or below (if possible) 3000 r.p.m.
Here is some more help...
http://www.itrca.com/FAQ/maintenance/maint.php
Have fun, and drive safely.
Old Sep 30, 2004 | 08:06 AM
haknslash2003's Avatar
Default Re: integraguy2001 (2001 Integra GSR)
Sounds like the O2 sensor to me. Usually when it goes bad, your MPG suffers horribly. Do yuor tune-up and check the O2 sensors voltage to ensure its working correctly.
Old Sep 30, 2004 | 10:50 AM
Default Re: integraguy2001 (haknslash2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haknslash2003 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like the O2 sensor to me. Usually when it goes bad, your MPG suffers horribly. Do yuor tune-up and check the O2 sensors voltage to ensure its working correctly.</TD></TR></TABLE>
What is O2 sensor? also, how expensive is it to change OS sensor
Old Sep 30, 2004 | 11:42 AM
TeaAddict's Avatar
Default Re: integraguy2001 (integraguy2001)
i was thinking it could be maybe a super dirty air filter that is restricting air flow into the engine? clean it or get a new air filter.
btw...how the hell do you guys get over 300 mi/tank city driving? you guys **** @ like 2k rpms?
Old Sep 30, 2004 | 11:48 AM
The O2 sensor is the sensor that reads and tells your Ecu how rich and lean to make the car. It is only operable until WOT and then the MAP sensor takes over. Depeneding if you have 0BD1 or OBD2 ecu, depends on the cost and if you need more than one. You can however use a 02 sensor off a 97 civic dx on a obd1 and it will work fine but you have to switch the wires. The civic sensor only costs $35 form any Honda dealer. Most people don't know this but it will definatly work. The average oem replacement O2 sensor will run you $120 for a OBD1 O2 Integra sensor.
Old Sep 30, 2004 | 11:49 AM
iixerOii's Avatar
I think you can get a NGK 02 sensor for like 60 bucks
Old Sep 30, 2004 | 11:50 AM
deviusdragger's Avatar
From: im nothing from no where im no one at all, ca
Default Re: integraguy2001 (TeaAddict)
when i drove all highway, i got 350 miles to the tank. in my gsr with just an intake and header. i put premium on my car. but just normal driving i get about 280 to the tank. maybe a little more. its pretty good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeaAddict &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking it could be maybe a super dirty air filter that is restricting air flow into the engine? clean it or get a new air filter.
btw...how the hell do you guys get over 300 mi/tank city driving? you guys **** @ like 2k rpms?</TD></TR></TABLE>
I know right... I have an auto, but that doesn't make that big of a difference.
I drive on highway most of the time.
My air filter was changed 10 k miles ago. did it myself.. fuel filter is hard to change. i heard.
Old Sep 30, 2004 | 01:49 PM
fuel filter is definatly not hard to change, just the bottom bolt can be a biyatch to get loose if it has never been loosened before. It takes apprx. 10 minutes tops lol.
Old Sep 30, 2004 | 02:13 PM
hotsuma23's Avatar
Holy ****, i dont know how you guys are getting 300 mpg city. I just went outside and checked my trip odo and i have 188 miles and i am sitting at just under 1/4 tank of gas. I filled it to capacity last time i bought gas. I dont drive very hard and usually shift at around 3k rpm. This is mostly city driving in bad Houston traffic in the mornings and afternoons. This is subpar and i am concerned that i am not getting enough mpg and i would like to do something to help it out. I am gonna check the fuel filter, plugs, wires, air filter. How do I check the O2 sensor to see if it is working good? BTW, the car is an OBD2 2000 LS 5-speed.
Old Sep 30, 2004 | 02:19 PM
W.O.P.'s Avatar
Default Re: My Teg's MPG is decreasing. (blacknbean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacknbean &raquo;</TD></TR><TR><TD CLASS="quote">i usually put in around 10 gallons on fillup and i get 250/260 out of that..so 280 isnt bad..but then again i race thru the gears everyday like no other </TD></TR></TABLE> cause your a ******* idiot..... you give the rest of us a bad name. i usually got 315 miles per tank. and i thought that was bad... guess it wasnt so bad
Alex98
Apr 12, 2019 05:04 PM
ncstater6b
Apr 16, 2010 08:53 PM
webster426
Honda Civic (2001 - 2005)
Jul 21, 2009 02:18 AM
hcivic99
Dec 23, 2004 08:44 AM
kingpen
Aug 31, 2002 09:27 PM
