Fluctuating Idle
Old Sep 29, 2004 | 01:49 AM
Nemesis_27's Avatar
Default Fluctuating Idle
When I start my car the RPMs go from 1000 to 2500 to 1000 and repeats. It will do this for about 20-30 minutes before it goes away. I put a jumper in the check engine light circuit and it flashed 14 ... IAC Valve ... so I replaced the IAC Valve and it is still happening, the check engine light still blinks 14. I hear a whistle coming from my car when I accelerate and was told that it was not loud enough to be a intake leak ... while a buddy of mine said that for sure it was an intake leak. My car also, jerks like it is stalling ... would be the best way to put it, when I accelerate into higher RPMs ... usually after 3000 RPMs ... my tachometer also jumps wildly when the RPMs are higher than 3000. I noticed the other night that if I am using my cruise control, I can accelerate much faster than if I use the gas petal without getting the jerkiness or the whistling sound ... the RPMs still jump around though.
I replaced the IAC Valve ... I have a spare intake manifold that I can replace mine with but would like to know if there is anything that I can do first ... so I do not have to mess around with a half-engine swap to get the thing out.
Thank You For Reading This!!!
Nathan a.k.a. Nemesis
Old Sep 29, 2004 | 04:50 AM
TOAB's Avatar
Default Re: Fluctuating Idle (Nemesis_27)
throttle position sensor?
Old Sep 29, 2004 | 04:43 PM
Slamaccord's Avatar
Default Re: Fluctuating Idle (TOAB)
i would say so ^
Old Sep 30, 2004 | 10:03 AM
Ped_Xing's Avatar
That's what was wrong with mine when it had those symptoms
Old Sep 30, 2004 | 01:39 PM
scrubachu's Avatar
Default Re: Fluctuating Idle (Ped_Xing)
definitely check the fast idle valve
Old Sep 30, 2004 | 03:08 PM
red92si's Avatar
Could also be air trapped in the cooling system. Remove your radiator cap and let it sit open for 10-20 minutes to let all the trapped air rise out of the system.
Your IACV filter screen may also be dirty and clogged.
Old Oct 1, 2004 | 06:28 PM
ricekiller1's Avatar
Default Re: (red92si)
yeah its either the THOTTLE POSITION SENCOR or the FAST IDLE VALVE...some times you have to clean the tps on the inside of the thottle body and some instances you have to replace the TB...thats my guess
Old Oct 1, 2004 | 07:40 PM
Schmitey's Avatar
Default Re: (ricekiller1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricekiller1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah its either the THOTTLE POSITION SENCOR or the FAST IDLE VALVE...some times you have to clean the tps on the inside of the thottle body and some instances you have to replace the TB...thats my guess</TD></TR></TABLE>
Roger that
Old Oct 3, 2004 | 08:47 PM
92accord69's Avatar
Default Re: (Schmitey)
Ya thats what was wrong with my accord, it would 'search' for an idle speed, it was set too high. I just turned the screw back and brought the idle speed to about 750 rpms, fixed it right away.
jawls
Feb 7, 2012 08:34 AM
zjigg2k
Jan 29, 2009 11:06 AM
Ahknodd
Oct 21, 2006 09:31 PM
Mr si99
May 5, 2005 08:31 PM
HybridGSR1
Jun 26, 2003 09:29 AM
