will a b20vtec pass smog?
Old Sep 28, 2004 | 08:09 PM
bpowa's Avatar
Default will a b20vtec pass smog?
well i want to know if anyone smoggeg a b20vtec, anywhere stock; will it pass the sniffer.
dont care about visuals...
Old Sep 28, 2004 | 08:33 PM
bossman032's Avatar
Default Re: will a b20vtec pass smog? (bpowa)
pre test my nizza
Old Sep 28, 2004 | 08:54 PM
bpowa's Avatar
Default Re: will a b20vtec pass smog? (bossman032)
pre test will fail at visual.. i will have to pay for illegal. my concern is sniffer
Old Sep 28, 2004 | 09:04 PM
zad5's Avatar
pretest at a place that doesnt care for visual. where do you live just wondering.
Old Sep 28, 2004 | 09:20 PM
irev210's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpowa &raquo;</TD></TR><TR><TD CLASS="quote">pre test will fail at visual.. i will have to pay for illegal. my concern is sniffer
sure, mainly depends on compression though
as long as it is tuned to pass smog, it will pass smog
Old Sep 28, 2004 | 09:39 PM
bpowa's Avatar
Default Re: will a b20vtec pass smog? (irev210)
MY COMP IS LOW ITS STOCK 9:1 COMPression.
i live in ca
Old Sep 28, 2004 | 10:17 PM
DOHCtorTHRUST's Avatar
you know what, it just might pass... if theirs no mods, it'll just be like a stock b20..
but you will fail visuals...thats a given...
Old Sep 29, 2004 | 06:33 AM
tttravis's Avatar
Default Re: will a b20vtec pass smog? (DOHCtorTHRUST)
the only way to pass this test is to move lets say to tn? we dont have visual inspections.....most counties dont even do emmisions.....i say move somewhere with none of that stuff
Old Sep 29, 2004 | 06:48 AM
smart monkey's Avatar
it probably could pass the sniffer if all is right but you just need a place where they don't care for the visual since that motor is a truck motor or classified as.
Old Sep 29, 2004 | 08:23 AM
bossman032's Avatar
Default Re: will a b20vtec pass smog? (smart monkey)
I had a b16a and ctr both never passed.
I tried everything. I spent around 1000 maybe more in trying to fix it never passed. NOX and HC were killing me at 15mph other then that everything else was fine close to pass but no close enough. Go get a pretest say that you don't want it to go DMV they should know what u talking about.
Old Sep 29, 2004 | 06:49 PM
allyourapex's Avatar
Don't think it will pass since the B20 is from a different vehicle class.
Old Sep 30, 2004 | 07:10 AM
bpowa's Avatar
Default Re: will a b20vtec pass smog? (allyourapex)
ok it is not passing i failed.. co is high at 15mph and 25, the guy was koo he let me do alot of playing with the car timing hoses, etc.. nothing worked.. i'mma try a new o2 sensor,
Old Dec 4, 2004 | 03:05 AM
2point2eg6's Avatar
Fact: a b20 series motor will not pass because it is a small truck motor...State referee rules are must go with year and newer with the same classifaction of car.
don't try becasuse they will give you a DMV notice that says some sh*t like:
ADVISED 27002 this vehicle is to remain of roads until fixed and all the cops have to do is scan it and tow your car..sucks
Old Jan 5, 2005 | 03:03 PM
Vo's96Ek's Avatar
its possible i just passed smog today with a b20vtec in my 4 dr integra'
Old Jan 5, 2005 | 04:57 PM
StorminMatt's Avatar
Default Re: (St8street)
Alot also depends on your car and where you take it to smog. If your car is equipped with a VTEC motor from the factory (ie GSR or 1999-2000 SI), you will probably pass visual. Chances are, the tech is not going to look at the block code to see what you have. All they will see is that your emissions setup is correct. If the car has a ref sticker for another VTEC motor, there is also a good chance it will pass visual. Although some shops check block codes, not all do. And if they don't, they will just test it as the VTEC motor that the ref sticker says you have.
Old Jan 31, 2005 | 10:21 PM
GapxGuy's Avatar
Sushi Buffet Champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St8street &raquo;</TD></TR><TR><TD CLASS="quote">its possible i just passed smog today with a b20vtec in my 4 dr integra'</TD></TR></TABLE>
How'd you do this? My smog check is due next month and need a solution fast. I got a B20vtec, 11:1cr, 290cc injectors, fuel rail, FPR, etc...
Is there a solution or will I have to drop back the D16? What's pre-test btw? Mine is Test Only btw.
Old Apr 21, 2005 | 12:08 AM
kinvid22's Avatar
Default Re: (GapxGuy)
my b20 passed the sniffer as a civic motor in my ek. this was almost two years ago, smog is due only months away. going back single cam
b-powa
Mar 13, 2004 07:10 PM
EsQueue
Jul 14, 2003 10:56 AM
MikeyDB7
Apr 18, 2003 06:30 AM
