how would you build this cage
Old Sep 28, 2004 | 07:58 PM
zc911's Avatar
Default how would you build this cage
i would post in 4x4 fourms but i ahve really not seen a well built stong cage in many off road trucks. Nothing that compares to some of the stuff i have seen some mebers here post sooo
here is the truck
-1989 suzuki samurai
-only worried about the 2 front passangers
-don't mind the rims they are on there as a joke, it will be on 33s
-has to withstand a roll over/barrel roll, and end overs (not that i am planning to do them but most common with a lifted narrow short wheel base truck)
-a pillars cannot go though the dash it has to eaither S around the sides of the dash with some support or cut the dahs and make it fit when the door is closed
hree is the pic, if you want some more from the back sides, whatever le tme know
Old Sep 29, 2004 | 08:47 AM
Overblown-Teg's Avatar
Default Re: how would you build this cage (zc911)
This should not be that hard to make. You could just run the bars straight up to the front hoop, in front of the dash all together. Then run the rear hoop and I would still put some bars to the back of the truck. That should be enough. Check out http://www.swracecars.com for some ideas on what a cage normally looks like.
Old Sep 29, 2004 | 09:36 AM
ScrapinSi's Avatar
http://www.off-road.com/suzuki...e.htm
http://www.cardomain.com/memberpage/533897/6
http://www.zukiworld.com/secti...r.jpg
those are some places to start...
ginahoy
Jul 14, 2016 01:51 PM
ekcoupeh22
Feb 8, 2013 05:03 AM
slowboy90
Nov 23, 2010 10:24 PM
Truong09
Honda S2000
14
Sep 19, 2007 09:26 PM
k279
May 28, 2004 04:01 PM
