antenna installation
Old Sep 28, 2004 | 06:20 PM
porkchop14's Avatar
Default antenna installation
does anyone hav a guide on how to uninstall and install a new antenna (93 accord) i kno that a special tool is need but how do i get it if its not sold in stores anything would help thanks
Old Sep 29, 2004 | 12:37 AM
Trumpster's Avatar
Default Re: antenna installation (porkchop14)
To the best of my knowledge, there are no special tools that you need. If you are just replacing the antenna, all you need to do is unscrew that little nut on the outside of the car that is at the base of the antenna and then pull it out from the inside of the trunk. You do have to pull back the trunk lining to get to it, but its easy to do. It's really a simple operation, after that, it's pretty obvious what needs to be plugged in to where. Just look at the stock one before you take it out and plug the new one in respectively. Do that in reverse, and there ya go, antenna installed. I have a 1990 so I wouldnt expect them to be much if at all different since they are the same generation. Hope that helped and GL
Old Sep 29, 2004 | 01:59 AM
The_Todd's Avatar
Farts in the shower
Default Re: antenna installation (Assassin247)
If you want you can do a s2k antenna...search there is a awesome diy .
But /\ sounds right .
Will14
Apr 8, 2011 03:42 PM
sobey
Mar 4, 2009 07:06 PM
bmw626
Jun 6, 2005 02:49 PM
