PR3 pistons in LSVTEC
Old Sep 28, 2004 | 04:47 PM
EGkid's Avatar
Default PR3 pistons in LSVTEC
I'm just wondering if any people on here are running pr3 pistons in their lsvtec setups. I was told they yield about 11.5:1 compression ratio with an oem 3 layer headgasket and a GSR head, is this true? Could it be more/less?
Also how big of a lift cam are you guys using. Plan on using toda b's and they require a 12 compression to be used to their full potential. Maybe a 1 layer headgasket?
Old Sep 28, 2004 | 04:54 PM
redcrx187's Avatar
Default Re: PR3 pistons in LSVTEC (EGkid)
i currently run the pr3's in my ls/vtec i got them .25 over with a gsr head your comp. will be slightly higher than mine i run the b16 and i believe my copm is around 12-1 but i also had a little taken off the head and block but not much
i would also stick with the oem head gasket and i also run the skunk2 stg 2 cams with skunk springs and retainers i ran the stage 1's for the first 7,000 miles or so and they are just fine for that app. i just changed a few things on my set up and needed a more agressive cam (by the way i have the stg 1's for sale and a full set of itr inner and outer springs )just to let you know
Old Sep 28, 2004 | 05:04 PM
EGkid's Avatar
Default Re: PR3 pistons in LSVTEC (redcrx187)
^^^ what layer headgasket are you using?
The compression calculator said i have about 11.3:1 compression with an oem 3 layer headgasket so i don't think i'd have more than you would. I also have a stock bore ls block and the head was not milled...
Old Sep 28, 2004 | 05:07 PM
redcrx187's Avatar
oem
Old Sep 28, 2004 | 06:05 PM
EGkid's Avatar
does anyone else also agree that i'd have a compression ratio of 12.1:1 or higher with pr3's and an oem headgasket?
Old Sep 28, 2004 | 07:38 PM
GOLDBERG's Avatar
no..i think ityd be lower...just a lil higher over yer previous guess
Old Sep 29, 2004 | 08:07 AM
EGkid's Avatar
Default Re: PR3 pistons in LSVTEC (GOLDBERG)
hmm...so with a 2 layer i assume i'd have about 12.0:1 or alil higher
i used the compression calculator but i heard it was a bit off, is that true?
Old Sep 30, 2004 | 08:57 AM
EGkid's Avatar
anyone else?
Old Sep 30, 2004 | 10:34 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGkid &raquo;</TD></TR><TR><TD CLASS="quote">I'm just wondering if any people on here are running pr3 pistons in their lsvtec setups. I was told they yield about 11.5:1 compression ratio with an oem 3 layer headgasket and a GSR head, is this true? Could it be more/less?
Also how big of a lift cam are you guys using. Plan on using toda b's and they require a 12 compression to be used to their full potential. Maybe a 1 layer headgasket?</TD></TR></TABLE>
Try its more around 11.8:1 to 11.9:1 CR!
B18 block
PR3 Pistons
oem gasket
B18C1 head
Old Sep 30, 2004 | 09:37 PM
EGkid's Avatar
Default Re: PR3 pistons in LSVTEC (hybrid_vtec)
bump, thanks for the input guys
Old Oct 1, 2004 | 09:01 AM
EGkid's Avatar
ttt
Old Oct 1, 2004 | 09:54 AM
Good Luck!
Old Oct 1, 2004 | 04:58 PM
EGkid's Avatar
thanks
Old Oct 2, 2004 | 05:23 AM
EGkid's Avatar
to the top
Old Oct 3, 2004 | 09:59 AM
HondaCivicSiR1's Avatar
im going with the same set up as you pr3 pistions ls rods b16a1 head and im putting it in a ef9
Old Oct 3, 2004 | 04:12 PM
99lsvtecauto's Avatar
Default Re: PR3 pistons in LSVTEC (HondaCivicSiR1)
going 2 be a little lower than the gsr gsr combustion chamber is welded a b16 is not
Old Oct 3, 2004 | 04:33 PM
EGkid's Avatar
Default Re: PR3 pistons in LSVTEC (99lsvtecauto)
yeah i was about to say my compression ratio would be alittle higher because of the gsr head
Old Oct 4, 2004 | 10:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGkid &raquo;</TD></TR><TR><TD CLASS="quote">yeah i was about to say my compression ratio would be alittle higher because of the gsr head</TD></TR></TABLE>
Yes it will!
Old Oct 8, 2004 | 03:25 AM
alloysr16s's Avatar
well what can i do to lower my compression? I am looking to use either b16 pistons or type r psitons . What kind of oem pistons should I use? What specific oem head gasket should I use. Everyone says oem 3 layer but where do I get them?
Old Oct 8, 2004 | 04:45 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: PR3 pistons in LSVTEC (alloysr16s)
I'm running 12.2:1 with CTRs and a OEM 3 layer.
Old Oct 8, 2004 | 05:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alloysr16s &raquo;</TD></TR><TR><TD CLASS="quote">well what can i do to lower my compression? I am looking to use either b16 pistons or type r psitons . What kind of oem pistons should I use? What specific oem head gasket should I use. Everyone says oem 3 layer but where do I get them?</TD></TR></TABLE>
If you want to lower your compression than you want to use B20 or LS pistons, but why do you want to do that unless you were going turbo!
monster_c
Apr 5, 2012 09:53 AM
Honda_Noob42385
Feb 26, 2009 04:52 AM
NSfit
Jul 25, 2006 09:47 AM
haggar
Jul 31, 2003 10:51 PM
VTEC-DA
Jan 4, 2003 07:33 PM
