Steering wheel not straight
I had an alignment done but when the tires are center, the steering wheel is not. I have a factory wheel. Is there any way to take it off without the airbag blowing off so that I can straighten it or is this something bigger? Any advice would be helpful.
To do the alignment right it should have been carried out while the steering wheel was locked in the centre position, while the alignment was carried out and I suggest to save you a load of hassle, in removing the wheel and all controls that you take it back and make them do it right as they should have done, cos what you've paid them for is really an alignment that dosn't align if you follow me ?
But if you really want to DIY here's a link to remove the stock wheel following safety tips, it's for putting on a S2k wheel but shows you the routine for removing the wheel safely.
http://www.ntpog.org/mods/fift...shtml
Diversion
Aug 27, 2006 02:16 AM
