How to plug 02 sensor hole on a cat convertor???
Old Sep 28, 2004 | 04:26 PM
gamby's Avatar
Default How to plug 02 sensor hole on a cat convertor???
Nutshell:
Installing EG Si OEM replacement exhaust on 92 CX. Obviously it comes up short.
I have an ITR cat lying around in my garage, which will make a nice test pipe, except for its open hole for the 02 sensor. I don't have an 02 sensor lying around, so I need to plug it somehow.
Is a sparkplug the same thread/size??? (I figure I could gring down anything unneccessary and screw it in).
OR, does anyone have a shot O2 sensor that I could pay shipping + 5 bucks for???
thanks
Old Sep 28, 2004 | 04:27 PM
dantastic's Avatar
i'm sure you can buy a bolt from a hardware store to plug it up. just remember to use some anti-seize if you ever want to get it out
Old Sep 28, 2004 | 04:28 PM
gamby's Avatar
Default Re: (dantastic)
Seems like that thread pitch is really odd, though.
Worth a shot, I guess
Old Sep 28, 2004 | 04:39 PM
Relic1's Avatar
No it's nto the same size as a spark plug and you will not find it in a hardware store. At least I couldn't around here. Something about illegal to sell or something like that.
I ended up in a little automotive shop that had a bunch of crap they were sending back for returns. One of the replacement cats had a plug. They gave it to me. :D
I have seen O2 plugs on some websites. I'm sure google "O2 sensor plug" would come up with something.
Old Sep 28, 2004 | 04:42 PM
BoostinEJ1's Avatar
oil plug works perfect, I forgot the size but if you search on here you will find it, I did it a while back and as long as you tighten it well your golden.
gamby's Avatar
Default Re: (Relic1)
Thanks!
Another user (sinitron) suggested that to me, too. Who knew such things existed??? Well, you and he did--not me.
*edit* was referring to the 02 sensor plug--not the oil plug (initially skipped over that)
Oil plug is a great idea, though.
Old Sep 28, 2004 | 05:01 PM
Slopoke's Avatar
Default Re: (gamby)
I'm pretty sure most exhaust shops will carry the o2 sensor plugs.
Old Sep 28, 2004 | 05:34 PM
Deemeetree's Avatar
Electrician
I'm pretty sure they can weld the hole shut.
Old Sep 28, 2004 | 05:53 PM
gamby's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure they can weld the hole shut.</TD></TR></TABLE>
I'd like to re-use that cat when/if I do a swap, so I'd like to plug it in a reversible manner.
Old Oct 5, 2004 | 05:47 PM
10secwantabe's Avatar
Default Re: How to plug 02 sensor hole on a cat convertor??? (gamby)
Oil plug. Take the pipe to the hardware store with you before you put it on the car!!
Old Oct 5, 2004 | 05:52 PM
gamby's Avatar
Default Re: How to plug 02 sensor hole on a cat convertor??? (10secwantabe)
I ended up using a 5/8" round metal plug from the Depot. Cost a buck and it snapped right in. No problems with it so far...
mattL
Apr 13, 2004 06:45 PM
greatgraffini
Jan 1, 2004 06:55 PM
RallySportCivic
Feb 9, 2003 09:25 AM
Isaac
Oct 21, 2002 01:31 PM
2001PYITR
Oct 15, 2002 12:13 PM
