sp. procedure for brake flush after PROP. VALVE swap?
just swapped over a bigger mc and a prop valve from a del sol si into my 93 dx hatch and i thought i recall hearing somewhere that after a prop valve change you are supposed to bleed it a certain way aside from the farthest-closest method.
anyone hear of this or am i just derp
Hope you bench bled that MC.
With any opening of the brake system you really should bleed the system and yes the helms manual states you bleed from furthest away from MC to closest. Some may argue the opposite, closest to furthest. In any case bleed it and bleed it well.
Mind as well do the clutch fluid too if you have a hydro tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 »</TD></TR><TR><TD CLASS="quote">Hope you bench bled that MC.
Mind as well do the clutch fluid too if you have a hydro tranny. </TD></TR></TABLE>
it was bench bled.
i know that they need to be bled as i changed mc, prop, and rear brakes, so there's like no fluid in the lines at all, i know how to bleed them the "usual" way but i was told there was a special sequence after u change the prop valve.
someone on here told me that napa has a brake bleeding book so im going to stop on by there thanks
it was bench bled.
civic_driver
18
May 26, 2010 08:22 AM
BlitzSix
Nov 5, 2008 09:35 PM
hybrid90
Suspension & Brakes
Oct 14, 2008 10:07 AM
