Wheel Info - Add yours (no bling)
Old Sep 28, 2004 | 03:33 PM
Driven's Avatar
Default Wheel Info - Add yours (no bling)
Figured I start this since I've been shopping again. I was looking for a variety of wheels. 16s for the street, 13s for Autocross, and 15s for the track (road course). Since i'm a budget racer, $150/ea wheels were not in my sight. Also, they are ALL 4x100 lug pattern... 5 lugs on a CRX is a waste and becomes a pain to find wheels. Without further adue:
BS - Back Spacing
Wheel
Size
Offset
Weight
Price
Where Purchased
Diamond Racing
13x9
5.5" BS
15lbs
$63/ea
Diamond Racing
Konig Helium
15x6.5
40mm
11.5lbs
$95/ea
Good-Win Racing
Konig Traffic
15x6.5
40mm
12.5lbs
$76/ea
Discount Tire
Konig Network
15x7
38mm
13.4lbs
$99/ea
Good-Win Racing
Enkei RSE (evolution)
16x7
45mm
17lbs
Discontinued
Discontinued
Enkei RS5
16x7
40mm
17.7lbs
$300/set
Ebay
Konig Hurry
15x6.5
40mm
13.6lbs
$89/ea
Good-Win Racing
F2 Alloy (slipstream copy)
15x6.5
40mm
12lbs
$99/ea
Good-Win Racing
Nippon Zen
15x6.5
13.4lbs
$99/ea
Good-Win Racing
Pro-Race 2
15x7
14lbs
$109/ea
Good-Win Racing
Konig Next
15x7
40mm
14lbs
$99/ea
Good-Win Racing
I ended up with the Bronze Konig Heliums and got them for DiscountTire at $95/ea. They were originally $111?/ea. The extra half-inch wasn't worth the extra 2+lbs on average to me.
There are several other choices, Koseis come to mind, that i didn't look up during my initial search due to cost and value. Kosei has a 15x7 in around 12lbs, but for $130+/ea. The 15x6.5 Konigs at 11.5lbs is a-okay for me.
Edit: No damn preview...
Old Sep 29, 2004 | 06:22 AM
Driven's Avatar
Default Re: Wheel Info - Add yours (Driven)
all that and no one cares... even some people made whole new threads about getting light wheels, ha!
this forum makes me laugh sometimes
Old Sep 29, 2004 | 07:04 AM
squeaky's Avatar
I feel ya. Hey thanks for posting all that wheel info. Seeing how you listed Goodwin, you've done your homework on lightweight wheels. I think you made a good decision on wheels, but did you also get hubcentric rings with the deal?
My previous track setup was 15x6.5 Rota Slipstreams with 205/50 tires, which held up nicely. Since that setup is long gone, I've splurged on stronger, lighter, wider wheels with 225/45/15 Kumho Ecstas and am very happy with the setup. For reference, this is on my Miata and not Civic (not tested for fender/suspension clearance yet, fitment is fine).
Which tires you plan on running on the 15s? And are you going with the Diamonds for 13s? I will most likely go for 13s for next season on my 86 Si.
My opinion on the 16s: skip it. I had a phase where "bigger = better looks" was my motto, but nowadays dig the look of 15s with minimal fender gap on CRX/Civics. I would go for another set of those 15s you got, slap on some new Azenis and have at it. In that case, this could also be your spare set of rains for the autocross or track. What ya think?
Old Sep 29, 2004 | 08:51 AM
Driven's Avatar
Default Re: Wheel Info - Add yours (squeaky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by squeaky &raquo;</TD></TR><TR><TD CLASS="quote"> I think you made a good decision on wheels, but did you also get hubcentric rings with the deal? </TD></TR></TABLE>
Nope. I've had (and heard) bad experiences with hubcentric rings... most are plastic and become brittle or insanely difficult to remove from the hub.
So, I run without them. Properly torqued lugs haven't failed me yet!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Since that setup is long gone, I've splurged on stronger, lighter, wider wheels with 225/45/15 Kumho Ecstas and am very happy with the setup. </TD></TR></TABLE>
I've thought about this and will most likely try it on the next set of wheels i'm most likely going to purchase. It'll probably be a 15x7 set and the current Konig Heliums will be used as a street set.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Which tires you plan on running on the 15s?</TD></TR></TABLE>
205/50-15 Kumho Victoracers. The Victoracers seem to handle heat better than the Ecstas and since I'll be using them as a primary track tyre...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> And are you going with the Diamonds for 13s? I will most likely go for 13s for next season on my 86 Si.</TD></TR></TABLE>
Yep. already got them, they have 235/45-13 Kumho Ecsta v700s. They work rather well. I got them with the 5.5" backspacing to ensure it clears the suspension. They look ridiculous on the car though, but, who cares... they work fabulous!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">My opinion on the 16s: skip it. </TD></TR></TABLE>
Well, i have a set laying around that i purchased to run 12" brakes. Now, I've swapped out the 12" brakes for the stock 9.5" brakes. I may go to 10.3"...which may eliminate the 13x9 wheel use, unfortunately. I'll have to research on this more though.
to recap, current:
Street - 16x7 Enkei RS5 - 17.7lbs - BFG G-force sports - 205/45-16
AutoX - 13x9 Diamonds - 15lbs - Kumho Ecsta V700s - 235/45-13
Track - 15x6.5 Konig Helium - 11.5lbs - Kumho Victoracer V700s - 205/50-15
Future:
Street - 15x6.5 Konig Helium - 11.5lbs - Falken Azenis Sports - 205/50-15
AutoX - same, unless won't fit over 10.3"
Track - 15x7 Konig Network - 13.4lbs - Kumho Ecsta V700s - 225/45-15
Old Sep 29, 2004 | 09:01 AM
EL Vap133's Avatar
Some good deals here: https://honda-tech.com/zeroforum?id=48
Old Sep 29, 2004 | 09:06 AM
eumoria's Avatar
Default Re: Wheel Info - Add yours (EL Vap133)
i have 3 brands on 4 tires
junkyard represent
Old Sep 29, 2004 | 10:07 AM
yellowcrx1991's Avatar
I thought CRXBart nailed it pretty good in the light racing wheels topic when he posted this.
http://www.wheelweights.net/
Old Sep 29, 2004 | 12:42 PM
Driven's Avatar
Default Re: Wheel Info - Add yours (yellowcrx1991)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowcrx1991 &raquo;</TD></TR><TR><TD CLASS="quote">I thought CRXBart nailed it pretty good in the light racing wheels topic when he posted this.
http://www.wheelweights.net/</TD></TR></TABLE>
This was a GREAT resource when i was looking, except it was missing offsets and prices/places to purchase.
Old Sep 29, 2004 | 05:18 PM
Driven's Avatar
Weight with tyres:
16x7 Enkei RS5 & BFG G-force sports - 205/45-16 -- 37lbs
13x9 Diamonds & Kumho Ecsta V700s - 235/45-13 -- 35lbs
15x6.5 Konig Helium & Kumho Victoracer V700s - 205/50-15 -- 31lbs
iHEARTMYCiViC
May 6, 2012 11:29 AM
Sean @ ESG
Nov 26, 2008 07:32 PM
nssnskyline2
Aug 11, 2005 12:57 AM
Jake
10
Mar 3, 2004 06:15 AM
JoeyBallzSI
Oct 20, 2003 03:04 PM
