98 accord battery drain
Old Sep 28, 2004 | 02:25 PM
98accordwesttexas's Avatar
Default 98 accord battery drain
battery on my 98 v6 accord just seems to drain for no reason. dealer says if they can't get code, then then can't find the problem. just replaced battery and alternator two weeks ago. any suggestions?
Old Sep 28, 2004 | 02:41 PM
C_H_A_D's Avatar
Default Re: 98 accord battery drain (98accordwesttexas)
do you have an aftermarket stereo system. There has to be something on all the time killing your battery
Old Sep 28, 2004 | 02:57 PM
Mike813's Avatar
Default Re: 98 accord battery drain (mood513doom)
yea aftermarket stereo systems take alot out of a battery if you are constantly cranking the sucker...
also check all the wiring on the alternator make sure everythings clean and tightly fastened...
Old Sep 28, 2004 | 05:54 PM
thanks, you are right about the drain and there is an aftermarket radio. but its strange. sitting over night does not cause any problems. its only sometimes and like today there was a couple of short trips and then it sat for 4 hours. when i tried to crank it, it seemed like the battery was down. i jumped it without any problems and put the battery on a charger and within a few minutes it was fully charged. i had the battery and alternator checked at local auto parts store and they said both were ok. i appreciate your input. thanks
Old Sep 29, 2004 | 01:35 PM
C_H_A_D's Avatar
short trips kill your battery your alternator doesnt have time to charge up but that still wont cause the battery to die. You have to have an axternal amp that always stays on lfor the battery to be drained completly.
Old Sep 29, 2004 | 02:24 PM
TOAB's Avatar
you dont have aftermarket pulleys by anychance do you?
kayelemenohpee
Sep 20, 2011 11:25 PM
the king.
Aug 7, 2008 08:25 AM
otip212
Oct 23, 2006 06:11 PM
jdm5ghb
Jan 10, 2004 06:09 PM
