how to install JDM side markers?
Old Dec 12, 2001 | 01:14 PM
RHGSR01's Avatar
New User
Default how to install JDM side markers?
Can someone give me the step on how i would install the side markers or give me any website that show u how to...thanks
Old Dec 12, 2001 | 02:17 PM
AllMotorITR's Avatar
New User
Default Re: how to install JDM side markers? (RHGSR01)
Drill a hole and connect some wires?
Old Dec 12, 2001 | 07:06 PM
YodaIsGod
Guest
Posts: n/a
Default Re: how to install JDM side markers? (1 FAST R)
why do you want sidemarkers? Why didn't you buy a audi/vw/bmw/m-b or somebother european car.
Old Dec 12, 2001 | 07:15 PM
RHGSR01's Avatar
New User
Default Re: how to install JDM side markers? (YodaIsGod)
BioTch, Cuz i Want side markers FOO! If you gonna hate that that shiet somewhere else. I aint dealin with ur childish mess. all i asked was for help not ur OPINION jackass.
Old Dec 12, 2001 | 10:51 PM
tightDA8's Avatar
JDM sidemarkers??? okay here we go:
first get some card board, posterboard, whatever.
draw the back of the sidemaker housing onto the card board.
cut a perfect shape of the rear of the sidemarker, put the sidemarker through it because this will be your template that you are gonna use on your fender.
one you have the template cut perfectly, put in on the fender where u want the hole drilled. (it helps if u look at pics of ur same car so u know where to position the sidemaker to make it look right)
when u have the placement correct, tape the template to the fender and draw the outline of it on the fender with a thin marker.
now, use a dremel moto tool to cut the hole in the fender. this is the hardest part bcuz u are now cuttin ur car!
once u have the hole drilled, snap the side marker in place.
Now, just wire up the two wires to ur turn signal. wire them to the bulb that blinks and stays on, so this way ur side marker will be on and blink at the same time as your bumper lights...
DONT **** UP ON THE PLACEMENT>MAKE SURE THAT IT IS STRAIGHT..
Hope this whole how to helps....!
Old Dec 13, 2001 | 05:33 AM
tr4il's Avatar
Uhm...peep this
Use This...
Need More Help?
You should't have a problem doing the job.
Old Dec 13, 2001 | 08:09 AM
YodaIsGod
Guest
Posts: n/a
i've been called worse. Sorry that I couldn't help you.
Old Dec 13, 2001 | 09:01 AM
tightDA8's Avatar
Default Re: how to install JDM side markers? (tr4il)
damn, that install is very helpful!
Old Dec 14, 2001 | 12:46 AM
speedymon's Avatar
Default Re: how to install JDM side markers? (tightDA6)
I hate sidemarkers that stay on all the time. When i had mine on my accord they would go off when i completed the turn. Just like the REAL European cars. I guess the JDM ones stay on.
Old Dec 14, 2001 | 11:23 AM
taytay333's Avatar
Default Re: how to install JDM side markers? (speedymon)
JDM corners and side markers are off all the time, except when signaling or you have your hazards on.
b20eg9
Mar 17, 2006 01:28 PM
SilvRGsR
Feb 14, 2004 12:38 PM
vietshinobi
Feb 10, 2004 11:30 PM
D16 madwoman
Dec 1, 2003 05:35 AM
