difference between the 94-01 gsr engines
Old Sep 28, 2004 | 11:32 AM
acintegragsr's Avatar
Default difference between the 94-01 gsr engines
whats the difference between a 94-98 and then 99-01 gsr engine if they have the same power i see stuff all the time about **** like headers and exhuast im just curious
Old Oct 4, 2004 | 05:50 PM
integra15's Avatar
Default Re: difference between the 94-01 gsr engines (acintegragsr)
94-95 had oil coolers, 96+ are obd2... I sure you could find more info if you searched.
Old Oct 4, 2004 | 05:59 PM
rovigian's Avatar
Default Re: difference between the 94-01 gsr engines (integra15)
i wanna hear more, im curious
Old Oct 4, 2004 | 06:15 PM
wlee2's Avatar
Default Re: difference between the 94-01 gsr engines (rovigian)
difference i know is OBD1 and and OBD2 older engines and new ones. i read somewhere that OBD1 is easier to mod (theres no real proof behind this i just read it) i didnt even know that 94-95 had oil coolers.. in australia the 2 different ages gave a different seat trim actually i got no proff on that either thats just an observation sigh i didnt help much did it sorry thats about all i know but im slowly getting there =P
Old Oct 5, 2004 | 04:35 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acintegragsr &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference between a 94-98 and then 99-01 gsr engine if they have the same power i see stuff all the time about **** like headers and exhuast im just curious</TD></TR></TABLE>For exhaust, the difference isn't in the engine. They used a longer A-pipe & a shorter cat in '99+. So people making headers & exaust systems usually maintain the interface points. That's because not everybody buys the whole system together, including the cat.
The differences in the engine were OBD-1 ('94-'95) vs. OBD-2 ('96+). More sensors, different ECU, not much REALLY different in the engine.
Old Oct 5, 2004 | 08:48 AM
BlackSage's Avatar
Default Re: difference between the 94-01 gsr engines (JimBlake)
00-01 gsr is OBD - IIb
96-99 gsr is OBD - IIa
94-95 gsr is OBD - I
Old Oct 5, 2004 | 09:02 AM
IN VTEC's Avatar
Most of the changes were b/c of the changes in the emissions systems.
EVAP purge system changed and the purge solenoid got moved to the middle of the manifold.
Lower timing belt cover changed from a P30 to P72 part number to make room for the CKF sensor.
The coolant air bleeder nipple formerly found on the upper radiator hose housing on OBD-1 engines was removed on OBD-2 engines.
Power steering pump and high-pressure hose line changed in '98. I'm not sure if this qualifies as part of the engine.
Fuel injector, distributor, and alternator wiring sockets changed in the switch to OBD-2.
FITV eliminated in OBD-2 engines.
Coolant routing changed to facilitate the lack of oil cooler, and the elimination of a nipple on the thermostat housing formerly used for the PCV purge hose. The plumbing is a bit simpler. See coolant hose routing diagrams in '94/'95 and '98 service manual for details.
91(si)hatchey
Apr 2, 2009 10:45 AM
GSRVTEC1
Nov 12, 2005 07:11 AM
zeroz
Sep 9, 2005 09:06 AM
97teggLS
Jun 3, 2004 05:17 PM
95integragsr1984
Dec 15, 2002 11:53 PM
