For those of you with main relay problems.
Old Sep 28, 2004 | 10:28 AM
DXDOHCVTEC's Avatar
Default For those of you with main relay problems.
If you are having main relay problems there is a quick easy way to fix it. (after you take it out) If you resolder the two points in the circle it should fix the common problem.
Old Sep 28, 2004 | 10:29 AM
Home Skillet's Avatar
Default Re: For those of you with main relay problems. (DXDOHCVTEC)
Holy eyesite Batman!
Old Sep 28, 2004 | 10:32 AM
DXDOHCVTEC's Avatar
hey mybad
Old Sep 28, 2004 | 10:38 AM
crx_88_si's Avatar
you have done this? no side effects?
Old Sep 28, 2004 | 10:40 AM
Creepshow S60's Avatar
Default Re: (crx_88_si)
i like my method of hitting it with a flathead screwdriver better. that way there isn't any removing of the relay, you can do it from the driver seat.
Old Sep 28, 2004 | 10:51 AM
DXDOHCVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">you have done this? no side effects?</TD></TR></TABLE>
I did this to mine and it works everytime. Now I can shut off my car at the gas station and it will start back up for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y-49CRX &raquo;</TD></TR><TR><TD CLASS="quote">i like my method of hitting it with a flathead screwdriver better. that way there isn't any removing of the relay, you can do it from the driver seat. </TD></TR></TABLE>
Once I had mine removed I bent the bracket and relocated it under the dash.
Old Sep 28, 2004 | 11:09 AM
89civicracer's Avatar
Resolder in place, or resolder together (so they touch)?
Man, that main relay problem was a bitch to pin point if you are not Familiar
with the civc's.
Old Sep 28, 2004 | 11:19 AM
DXDOHCVTEC's Avatar
Default Re: For those of you with main relay problems. (89civicracer)
Yes you just resolder what is there DO NOT LET THEM TOUCH.
Old Sep 28, 2004 | 11:46 AM
yellowcrx1991's Avatar
Some of us are the suck when it comes to soldering.
Like me.
Old Sep 28, 2004 | 12:38 PM
cvcrcer's Avatar
Default Re: For those of you with main relay problems. (yellowcrx1991)
Just to be fair, this sometimes doesn't fix the problem. I just finally dropped $60 to buy a new relay because I soldered it twice and it still failed sometimes. For $60 I thought it was worth it not to have the headaches at the gas station. Go here to http://www.hondaautomotiveparts.com/ for a good price on it.
Old Sep 28, 2004 | 01:07 PM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicracer &raquo;</TD></TR><TR><TD CLASS="quote">
with the civc's.</TD></TR></TABLE>
turn key on , listen for fuel pump to prime.
seems pretty straightforward to me , Honda or no...
Old Sep 28, 2004 | 02:06 PM
hatchblack's Avatar
Default Re: For those of you with main relay problems. (cvcrcer)
the way i look at it - why go through all the trouble of taking the thing out, taking it all apart, putting a little solder in, putting it all back together, plugging it in and hoping it still works, when i can go to the dealer, pay $40, and plug in a brand new factory relay that will work for many more years to come.
Old Sep 28, 2004 | 02:12 PM
Jonathan_ED3's Avatar
Because the opportunity cost is too great; especially when most of us already have all the soldering equiptment necessary to fix [usually] the problem.
Old Apr 20, 2005 | 04:57 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (Jonathan_ED3)
Well, I pulled my main relay yesterday and reflowed solder in all of the joints that appeared to be cracked [I had four obvious cracks]. Hopefully no more 'no start' conditions this summer [I was PLAGUED with them last summer].
I also relocated my main relay so it's a little more accessable in case I have to pull it out again. I just put it near the hood release.
Here's a small diagram that may help if you're wondering what goes where in the relay:
tdizz07
Sep 6, 2008 12:08 AM
upinsmoke
Jul 27, 2006 09:02 PM
2point2
10
Jun 4, 2006 09:25 PM
TealCivic93
May 29, 2006 06:28 AM
bustah49
Aug 23, 2004 12:21 PM
