Gear Ratio Calculator for B Series Transmissions
So, i made an excel calculator to help me out, and i prettied it up so other people could use it. it will calculate MPH and RPM drops for a transmission. plug in the final drive ratio, transfer case ratio, and 1-6 gears, shift RPM per gear, and it'll pop out the numbers. it'll even let you compare side by side what two tire sizes will output in MPH. I've listed both Hydro and Cable trannies with their requisite gear ratios.
if you guys can think of anything i can add to it, let me know. i'm thinking i could add kph to it for people not use to imperial.
i made this because i got sick of plugging in numbers between the miata.net tire size calculator and the gear ratio calculators out there.
click for zip file
click for zip file
the link for the ZIP file is in the OP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bummster »</TD></TR><TR><TD CLASS="quote">
click for zip file</TD></TR></TABLE>
looks like a dead link though
https://honda-tech.com/zerothread?id=1922582
look here maybe <U>Bense</U> has it stashed he knows too much anyway
