are mugen oil and rad caps "performance" upgrade?
Old Dec 12, 2001 | 12:44 PM
Hukd Up's Avatar
Default are mugen oil and rad caps "performance" upgrade?
well.....are they?
jason
Old Dec 12, 2001 | 12:51 PM
ITR764's Avatar
Default Re: are mugen oil and rad caps "performance" upgrade? (out_a_bounz)
the rad cap is, oil cap isn't. although i did see a real time r break the plastic one cause it hit the hood. so maybe the oil cap can be???
Old Dec 12, 2001 | 12:54 PM
NewYorkTypeR's Avatar
New User
Default Re: are mugen oil and rad caps "performance" upgrade? (Fuzznuts)
If it says mugen or spoon than it is.
Old Dec 12, 2001 | 12:56 PM
ZygSpeed's Avatar
what about those people who are boosting more than 1bar?
I hope you're not feeding your valve cover boost!
Old Dec 12, 2001 | 01:03 PM
ceas's Avatar
Bahahahahaha.. I guess that would mean that a vinyl stripe is a performance upgrade as well because the air has less turbulance over vinyl than rusty paint?? A high pressure radiator cap is nothing more than a bandaid for a poorly functioning cooling system..
ceas
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: are mugen oil and rad caps "performance" upgrade? (zygspeed)
Exactly. My beater is running over 1 bar of boost on a stock, plastic, LEAKING (bad seal) oil cap.
The Rad cap is, the oil cap is for show.
Old Dec 12, 2001 | 02:46 PM
b00st-0wnz's Avatar
Default Re: are mugen oil and rad caps "performance" upgrade? (raprazant)
rap: will you stand by your rad claim if I prove that the spoon cap will cause lower water temps?
I agree completely regarding the oil cap, but thanks for your obviously professional opinion. I mean, hell, you sure sound like a professional!
Old Dec 12, 2001 | 02:55 PM
Black SVT's Avatar
Default Re: are mugen oil and rad caps "performance" upgrade? (Dave-ROR)
Uh oh,Looks like we have a new troll.14 posts and climbing.
Old Dec 12, 2001 | 02:56 PM
Flux's Avatar
I get tired of people worrying about if a part is "performance" or if it is "show" or even worse yet "rice"...
Is the Spoon oil cap a performance part? - NO. Will it look better in my engine bay than the cheap black plastic one? - YES. Are appearances important to me? - YES, I try to find that zen-like balance between power and beauty in my R.
Stop telling me it is a waste of my money. Does a $8 plastic watch tell time? - YES, but I think I like wearing the Tag Heuer much more...
Old Dec 12, 2001 | 03:13 PM
B2FiNiTY's Avatar
Radiator caps = yup
Oil cap = Show
Old Dec 12, 2001 | 03:37 PM
ITR764's Avatar
Default Re: (ceas)
A high pressure radiator cap is nothing more than a bandaid for a poorly functioning cooling system..ceas
sorry, but my cooling system is working fine... (2k itr so it better be) the rad cap is to help improve it. so i guess you'd say the same thing about a spoon thermo switch???
Old Dec 12, 2001 | 03:50 PM
ZygSpeed's Avatar
Mugen, ARC, Spoon .... caps are rated at 1.3 bar vs. 1.1 for the stock cap, therefore increasing the temperature at which the "coolant" will theoretically boil!
Post a picture when you've done your "dirty deed".
Old Dec 12, 2001 | 03:52 PM
ITR764's Avatar
if you've got a radiator cap that categorically drops coolant temp over stock i'll crap a cinder block in the middle of my street.
i could possibly believe you if you present a logical argument just don't tell me that it's because the cap's made out of aluminum.
http://s2000.vtec.net/underhood/radiator_cap.html
[Modified by ITR764, 7:55 PM 12/12/2001]
Old Dec 12, 2001 | 04:09 PM
Flux's Avatar
if appearance is your m.o. then you'd obviously be interested in both of these parts, which is fine. if you're solely concerned about performance then you're looking in the wrong place.
my other point was just to say that if you end up putting a lot of money into ehancing appearance you'd better compete at some point.
Performance is always the number 1 priority - but nothing wrong with looking good while you are at it...
Old Dec 12, 2001 | 04:12 PM
ZygSpeed's Avatar
"If you live in a hot environment and drive your car very aggressively for extended periods of time (like at a track day), then I would say the radiator cap is an easy, justifiable modification to make.
Bingo!
I don't necessarily fully put to use the full extent of my suspension, brakes and tires all the time either, but it's there when I need it! ... whatever.
But too much shiny styff hurts my eyes.
Oh, and a Tag-Heuer ... anyone can buy one of those, But now my Mugen-Honda watch ... that's different!
Old Dec 12, 2001 | 04:21 PM
ITR764's Avatar
keep this up and the newbie will hit 20 posts tonight!!!! wooohooo
ed, i have a feeling as to why that shinny chit hurts your eyes
[Modified by ITR764, 8:22 PM 12/12/2001]
Old Dec 12, 2001 | 04:26 PM
ZygSpeed's Avatar
Default Re: are mugen oil and rad caps "performance" upgrade? (ITR764)
Could be!
Gee, never dawned on me.
man my memory's been bad lately...
hahaha!
Old Dec 12, 2001 | 04:51 PM
ITR764's Avatar
well the whole point is that when your tracking your car you need everything you can get to, help it run cooler, stop better, handle better. the r is good from the factory so i don't want to go buy a fluidyne, but instead put in a thermostat, rad cap, and thermo switch to help cool things down.
Old Dec 12, 2001 | 05:06 PM
Cold Chunker's Avatar
Who here has overheated their ITR?
summer?
race track?
idle traffic?
a/c?
I haven't even come close and I do all of the above.
Makes you wonder - are you getting a necessary perf upgrade or are you getting played by the marketers. Hmmmm.
Old Dec 12, 2001 | 05:10 PM
ZygSpeed's Avatar
Default Re: are mugen oil and rad caps "performance" upgrade? (98ITR461)
There may have been one or two people ar Buttonwillow this summer that "were hot", but mostly hi-po Jun civics.
Old Dec 12, 2001 | 05:25 PM
hybrider's Avatar
i tweaked the fan switch so basically when the key is in the ignition the fan comes on, i also just installed the spoon thermostat, btw not using the stock civ radiator but one off a `95 GS-R, plenty and enough to keep it very cool
Old Dec 12, 2001 | 07:05 PM
mugenr#1011's Avatar
no, but any one of the modifications you mentioned represents a significant improvement over stock. the few degrees that the aftermarket cap raises your coolant boiling point is negligible because 95% of the time your car would've been fine without it. that's opposed to 100% of the time that your shorter springs and better shocks or larger brakes are improving performance.
and to the dude who called me a troll, yeah i'm harsh but i thought that this was a technical forum. i'm really only here to exchange knowledge of c5 motor modification so i don't usually post the fluffy i love my r crap.
first of all the dude who called you a troll is a local freind of mine, and he know's his **** so dont flame. plus i have both of those part's mentioned above...and i didnt get them just for show..i got em cuz i had the money and i like mugen....i could see the radiator cap as a performance mod(track only) as far as the oil cap goes..well it sure does look better than the stock one.
Old Dec 13, 2001 | 06:18 AM
b00st-0wnz's Avatar
"If you live in a hot environment and drive your car very aggressively for extended periods of time (like at a track day), then I would say the radiator cap is an easy, justifiable modification to make. Don't expect your car to accelerate any faster though. However, for every day driving in cool weather, don't bother replacing the radiator cap until the stock one is worn out from age. "
Like Ed said.. Bingo!
Performance does not JUST equal acceleration. There is braking performance, suspension performance, cooling system performance, etc, etc, etc. Hell an Oil cooler wont give you 50hp but it'll get the oil temps down for sure. Not all of us just drive our cars back and forth on the street.
Old Dec 13, 2001 | 07:04 AM
ITR764's Avatar
dave, let just give up. some people just don't get it...
now would be a good time to show some pics of your car, see what they think about that upgrade.
Old Dec 13, 2001 | 07:05 AM
ITRbroham's Avatar
shit post warrior
Who cares?...if you have the money and you like these items get em'!
