Best way to remove OEM pedal covers
Like I said, What's the best way to remove the OEM rubber pedal covers on the pedals?
I've got an Idea'r and need to remove the cover's first.
(either heavy-duty rivet some pedals made from CF sheets and grip tape, or just some grip tape on the metal pedals)
_DIY@ccord!
_DIY@ccord!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">just pull 'em off, mine came off with no troubles.</TD></TR></TABLE>
im not sure if thats how the Auto ones come off, but the manual ones are just held on by the little lip of the rubber pad.....
i got some Razo pedals (they were a xmas gift from a buddy)....carbon fiber w/ rivets, and an extra lip on the brake and gas pedal, so my big clumsy feet can heel-toe easier when im in the winter dorifito driving mode
Thats what I figured...but has anyone removed them and put them back on? That's what i'm really wondering about is if I do remove the, how hard is it to get them back on?
_DIY@ccord!
_DIY@ccord!
removing takes about 2 seconds each, putting them back on, another 5 seconds....but once again, thats only for the manual.....
Remove by pulling, install by pushing. The pedal covers have a lip that covers the metal part of the pedal and is very easy to remove/install. I got a set of MOMO pedals installed, except the throttle pedal since it's a solid piece of plastic that I couldn't remove, nor I tried very hard.
It shouldn't take longer than 5 minutes, beer brake included.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BETO736 »</TD></TR><TR><TD CLASS="quote">
is your's a 7th gen?
Has anybody removed the pedal covers from an automatic 5th gen?
</TD></TR></TABLE>is your's a 7th gen?
yes, i have. they are really stiff and sort of a pain, but it is a simple process. if you can get one corner off, the rest are easy. but that first corner, especially on the brake pedal are a PITA.
now, the gas pedal is another story. that one has the cover molded onto it i think. i couldn't get mine off. maybe try an Xacto knife (if you don't want to keep it) because when i drilled for my new pedals, it is just a rubber cover over a metal pedal (like the brake pedal). but i don't know if it comes all the way off. i do not believe that it does.
that what you're looking for?
EvenStar
Sep 1, 2008 08:56 PM
RACEPAK
11
Mar 23, 2007 01:50 PM
