Surging idle after hitting VTEC
Old Sep 28, 2004 | 12:07 AM
Mr_CRX's Avatar
Default Surging idle after hitting VTEC
Ok, so I'm trying to work out all the little quirks on my b18c1 swap.
On initial startup, car idles fine at ~750, and even after driving around normally, will keep a nice idle there.
However, if you get on it and get into VTEC and then come down to a stop, the idle will surge from 1k-2k. If I hit VTEC and keep cruising around for a few minutes without coming to a stop (like flooring it on the onramp to get up to speed and then cruising on the freeway for a few miles), it wont surge when I eventually do some to a stop.
I've cleaned out the IACV, tightened up the FITV, etc.
ECU is chipped (using crome) but only to move the VTEC point due to my skunk2 manifold.
Any ideas?
edit: Oh yeah, if I turn the car off and restart it, it will reset it and idle fine until you get into VTEC again.
Modified by Mr_CRX at 1:24 AM 9/28/2004
Old Sep 28, 2004 | 09:07 AM
Mr_CRX's Avatar
Default Re: Surging idle after hitting VTEC (Mr_CRX)
bump. anyone?
Old Sep 28, 2004 | 10:04 AM
crx_88_si's Avatar
hrm.. thats a weird one u got there... tried burpin the coolant system?
Old Sep 28, 2004 | 10:56 AM
Mr_CRX's Avatar
Default Re: (crx_88_si)
No I havent. I'll try that.
Any other ideas?
Old Sep 29, 2004 | 01:12 AM
honda_power69's Avatar
Might be a quirk with Crome. I'd try using something like Uberdata to burn a stock bin file onto a new chip (or that same chip if its the AT29C256.
Old Sep 29, 2004 | 12:01 PM
Mr_CRX's Avatar
Default Re: (honda_power69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_power69 &raquo;</TD></TR><TR><TD CLASS="quote">Might be a quirk with Crome. </TD></TR></TABLE>
Possibly, but it would still idle like this on the stock ECU as well, even before I chipped it.
Bj Le Det
Jan 6, 2017 12:06 AM
jdmeurorlude
Feb 8, 2009 05:07 PM
celticthor
Dec 12, 2008 11:18 AM
Red_Si
12
Feb 16, 2003 04:17 PM
