im going with toda spec b need help
ok i have preped my car for my todas
i have a bi8c with edelbrock victor X intake w /JG 65mm throttle
aem fuel rail, fuel filter,fuel reg, 195lt fuel pump
marren injectors made for 200+ hp
jdm type r tranny with 4.7 final ACT xtreme Clutch with street disc and exedy light weight fly wheel and jdm type r headers
i love this stock set up i have great throttle response awsome take offs and
an rsx type s cant touch me trust me!!
but im ready for my toda's i was going to use todas recommended valve train as well and port and polish the **** out of it but im stuck on what to do with the bottom end like what compression to run or what bore size
im a daily driver but loves to haul *** any one have any advise let me know thanks -henry
81mm, anywhere between 12:1 and 12.5:1 compression, 93 octane!
oh, i'm curious as to why you didn't decide to go with the toda Cs. same price. just wondering is all. sounds like a cool setup.
high 11 CR and mid 12's will be enough compression for the Toda b's. with taht compression Toda c's will not be at their full potential. the b's will. anyway.
JE makes some pistons that will put that b18c into the 12.5 CR range.
sounds like a nice setup you got there. you can keep the factory bore size for that kind of compression. if you wanna sleeve it and all that then higher compression and c's would of been awesome. higher compression just makes it a little less streetable and tunable( for the street).
thanks it really is a great setup but what typre of ecu should i run ive been waiting to buy a stand alone aem but ive been waiting to see how my cames do
thanks bro
thanks bro
with those todas your gonna definetely need some kind of management system. you might not have to go all out with the AEM but Hondata, Uberdata, or a GOOD base program with a VAFC should be perfect for tuning a setup like yours.
p28 with a..like i said ...a good base program, maybe ripped from a person with a setup close to yours would be good.
Toda Built
12
Jan 19, 2004 02:19 PM
GQ 05YellowEVO8
Sep 4, 2002 03:15 PM
AllMotorITR
Oct 13, 2001 10:19 AM
