Crx hf
Old Sep 27, 2004 | 08:15 PM
B20CR-X's Avatar
Default Crx hf
How do I change the timing belt on my d15b6 crx hf?
Old Sep 27, 2004 | 08:16 PM
dr_latino999's Avatar
Default Re: Crx hf (2nd_gen_crx)
Well then, the easiest way to do it would be to buy a manual. Hell, even the one you get at Autozone would work
Old Sep 27, 2004 | 08:20 PM
B20CR-X's Avatar
Default Re: Crx hf (dr_latino999)
I did but my dad left it outside last night. Its trash now cause of all the rain. What I really need to know is how do I keep the crankshaft still while i loosen the pully?
Old Sep 27, 2004 | 08:48 PM
XrcR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2nd_gen_crx &raquo;</TD></TR><TR><TD CLASS="quote">I did but my dad left it outside last night. Its trash now cause of all the rain. What I really need to know is how do I keep the crankshaft still while i loosen the pully?</TD></TR></TABLE>
Some people remove the flywheel inspection plate and jam a big flathead screw driver between the teeth on the flywheel and transmission casing.
Alternatively, you can also use a strip of scrap metal with two holes in it. It only needs to be ~ 1" x 3", with the each hole towards the end. Use a bolt from the flywheel spection cover and fasten the metal piece to it via one hole. On the other hole, line it up with one of the threaded holes in the flywheel. You'll need to find a metric bolt that fits it however.
Either of these usually give enough holding power to keep the engine from spinning while wrenching on the crank pulley bolt. Of course it would help to have a big breaker bar or impact gun.
Old Sep 27, 2004 | 08:49 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2nd_gen_crx &raquo;</TD></TR><TR><TD CLASS="quote">I did but my dad left it outside last night. Its trash now cause of all the rain. What I really need to know is how do I keep the crankshaft still while i loosen the pully?</TD></TR></TABLE> Impact gun
I made a crank pulley holder out of some galvanized gas fittings.
Found a fitting that fit perfectly in that hex slot (b-series). Used a 18" pipe wrench to hold it in place. 1/2" breaker bar with 3' extension. Took me the whole day to get it off. Impact gun
Jm vtec
Jun 12, 2016 09:32 PM
CRX1.4DualCarb
Dec 25, 2006 09:15 PM
J_J
18
Nov 22, 2006 10:45 AM
Evolution Type R
May 2, 2006 11:43 PM
CRX_Control
Dec 10, 2004 10:24 AM
