Slippin and cant get up
Old Sep 27, 2004 | 07:38 PM
luv2drivecrx's Avatar
Default Slippin and cant get up
Alright, i got a 91 crx dx and i know that my clutch has to be on its way out. Each gear starts to slip as soon as i push the car over 3,000rpm. Really sux to deal with and its not getting any better. What i want to ask is if there is anything i can do to prolong the clutch just for another month or so until i can pull it out of commission for the winter for it to go under the knife. I dont want to put a new clutch in only to run it for a couple more months and then pull it all out of the car again and never use it again. Any info will help alot.
Old Sep 27, 2004 | 08:16 PM
CRX T-Si's Avatar
Default Re: Slippin and cant get up (luv2drivecrx)
There is no way around something like this man.
If you need a clutch then you need a clutch nothing u gonna do will make it last longer.....well unless you don't drive it of cause.
Look at it this way, if you fix it now then you don't have to worry about it later.
Old Sep 27, 2004 | 09:10 PM
Donkey85's Avatar
Default Re: Slippin and cant get up (CRX T-Si)
you can adjust it as far as it will go it will give u a lil extra life out of it i did that to mine when it was going i got it to last for a little while long when i changed it the clutch disk was half way through the rivits on it
Vinde
Transmission & Drivetrain
Oct 23, 2014 11:42 PM
beesting00si
13
Dec 2, 2008 10:36 PM
CRXsiproject
Aug 30, 2005 07:50 PM
Flux
Nov 26, 2003 11:25 PM
pr0digy1
Apr 18, 2002 09:59 AM
