Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
I just purchase a 88 DX 4 door running in EP...Please help..
Old Sep 27, 2004 | 07:00 PM
Conernr1's Avatar
Default I just purchase a 88 DX 4 door running in EP...Please help..
I will be using this car for autocross only. (maybe a few track days)
I would like to do a motor swap, but what engine and what class would it put me in?
The car has no interior, but is stock. A d15 motor.
What mods really make a differents, and are not just for show.
Thanks
Glenn
Old Sep 27, 2004 | 08:58 PM
Eee Pee's Avatar
Default Re: I just purchase a 88 DX 4 door running in EP...Please help.. (Conernr1)
Work on the suspension, refresh the bushings, get good shocks, and stiff springs.
Get some 20x9.5x13 slicks for the front, and 20x8 for the rear.
Getting the car to handle the way you want will take a few tries on the set up.
Then learn how to drive it, and then worry about the motor swap.
You can put any of the non vtec D series motors in there.
A motor swap from another chassis will put you in a Mod class without the interior.
Welcome to EP, it's fun.
Old Sep 28, 2004 | 03:11 AM
Conernr1's Avatar
Default Re: I just purchase a 88 DX 4 door running in EP...Please help.. (Eee Pee)
Thanks,
I have be autocrossing for about 3 years.
This is a winter project for me.
What spring rate and set up do you recommend? Konis with coil overs?
I looked at your car no dash or radiater? what do you wieght in at?
What Mod class does the car go to SM, FM? SM has a better pax than EP?
Thanks
Glenn
Old Sep 28, 2004 | 05:45 AM
SMSP's Avatar
The 88-91 CIvics are all on the same line in the SCCA rule book for EP so you can use any of those engines. Your min weight will be a little more with the D16A6 Si engine but probably worth it for the extra torque.
I have a 91 Civic 4 door as my beater that I'm getting ready to do some product testing on. It's already been on the dyno. However, I have a D16Y7 swap in it but still using the dual point fuel injection from the 91 car. A header, cat and 2-1/4" cat are the first things to be going on (hopefully next week). I'll probably run some PM7 pistons and go with the A6 IM since we have a few of those laying around. BTW, the engine with the DPI did 79hp/80 lb-ft, WOW! But it does get 36 mpg and that's why it's a beater.
If you need some extra D16 parts, hit me up.
Old Sep 29, 2004 | 03:19 AM
Conernr1's Avatar
Default Re: I just purchase a 88 DX 4 door running in EP...Please help.. (SMSP)
OK so if I read the rule book right I can only swap a motor from Appendix A. But does this mean any motor from the hondas listed or only from CIVIC (88-91)?
Does "same line" mean line on honda's or line of type?
Can I do a B16A1 swap?
I would go to SM (Better Pax) but the full interior is gone including the heat! I still have the dash unlike you... I'm be remove that so and just making a small gauge custer.
Thanks
Old Sep 29, 2004 | 03:40 AM
ohtheguilt's Avatar
You can't use a B-series motor and still stay in EP. Also, you cannot go to SM because of the lack of interior (heater core, etc.) if you use a B-series...in that case, you would make the jump to (I believe) DM.
Old Sep 29, 2004 | 03:48 AM
Conernr1's Avatar
Default Re: I just purchase a 88 DX 4 door running in EP...Please help.. (ohtheguilt)
Thanks
Can I go with a ZC or only the D motors?
Old Sep 29, 2004 | 05:19 AM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Conernr1 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks
Can I go with a ZC or only the D motors?</TD></TR></TABLE>
For EP you can only use engines from the 88-91 Civic, so I think I'd go with the D16A6 and stock FI. You need to read the rules about what mods are allowed with the stock FI because some mods will get you a 10% weight penalty.
Old Sep 30, 2004 | 05:00 PM
Conernr1's Avatar
Dave,
What is a good time to call you?
I live in Richmond Va. I would like to take to you about a swap.
Glenn
Old Sep 30, 2004 | 05:11 PM
Conernr1's Avatar
4G ’89-’91 Civic Si USA ED D16A6 1590 9.1:1 108hp@6000/100lb-ft@5000
4G ’88-’91 Civic DX USA ED D15A 1493 92hp@6000 L3
4G ’90-’91 Civic EX USA ED D16A6 1595 113hp@6200 L3
4G ’89-’92 Civic 1.6i/VTi Europe EE/ED B16A1 1595 10.2:1 158hp@7600/111lb-ft@7000 Y1 (opt. LSD)
4G ’88-’91 Civic Si Japan EF ZC 1595 9.6:1 129hp@6800/106lb-ft@5700 L3
4G ’89-’92 Civic SiR Japan EF B16A 1595 10.2:1 158hp@7600/112lb-ft@7000 Y1 (opt. LSD)
If all of the above engines are listed for 88-91 CIVIC why can I not use them and stay in EP?
Glenn
Old Sep 30, 2004 | 06:54 PM
jsi's Avatar
jsi
They have to be USDM spec motors available in US cars. The ZC and B16 was never offered in a US 88-91 Civic.
Old Oct 1, 2004 | 05:01 AM
SMSP's Avatar
Default Re: I just purchase a 88 DX 4 door running in EP...Please help.. (jsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsi &raquo;</TD></TR><TR><TD CLASS="quote">They have to be USDM spec motors available in US cars. The ZC and B16 was never offered in a US 88-91 Civic.</TD></TR></TABLE>
What he said.
Glenn, call me after 12:30 today.
Old Oct 3, 2004 | 05:23 PM
Conernr1's Avatar
OK I'm going to run EP next year.
Do a D16A6 swap
Koni Coilovers
13" Wheel put the rule book states 15x7 So doesn't that mean the I can only run 13 X 7?
Thanks
MotsoWRX
12
Jun 8, 2011 08:27 AM
Louie B.
Jul 14, 2002 10:36 PM
lodown414
13
May 21, 2002 08:56 AM
strykr
Mar 22, 2002 12:49 PM
