Anybody have energy suspension motor mount inserts?
I got these things A long time ago and put in the two side ones but not the rear because it was too hard to get at. I'm put it in now but thats because I pulled the motor to rebuild it. But my Question is Did it make your car(wheel,shifter.etc) shake alot during idle?
mine doesnt shake at all till the idle gets down below 1000, above that, feels the same as before.....and yea the steering wheel just vibrates a little and the dash makes some noise, but nothing bad...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StatGSR »</TD></TR><TR><TD CLASS="quote">mine doesnt shake at all till the idle gets down below 1000, above that, feels the same as before.....and yea the steering wheel just vibrates a little and the dash makes some noise, but nothing bad...</TD></TR></TABLE>
same here fella
same here fella
ditto. i love them.
ditto. i love them.
same here
same here
You get so used to it after a while that you think that cars without them don't have motors and run solely on hopes and dreams.
on a related note.....will these increased vibrations possibly cause bolts to just loosen up ?
not tryin to jack ur thread 95Jdmgeezer just figured it might be interesting to talk about this since its related. anyways, i have inserts as well, my car doesn't shake but it does vibrate. mainly above 4k rpm. but i have noticed that on occasion a couple of bolts have come loose. (1-bolt on top of tranny, 1-on rear mount, 1-front mount, 1-ground on tranny). i am very meticulous about tightening bolts down, so the increased vibrations are the only thing i can attribute to the bolts loosening up.
Me too hit that one on the button. Car felt much better though using them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cjsls »</TD></TR><TR><TD CLASS="quote">on a related note.....will these increased vibrations possibly cause bolts to just loosen up ?
not tryin to jack ur thread 95Jdmgeezer just figured it might be interesting to talk about this since its related. anyways, i have inserts as well, my car doesn't shake but it does vibrate. mainly above 4k rpm. but i have noticed that on occasion a couple of bolts have come loose. (1-bolt on top of tranny, 1-on rear mount, 1-front mount, 1-ground on tranny). i am very meticulous about tightening bolts down, so the increased vibrations are the only thing i can attribute to the bolts loosening up.</TD></TR></TABLE>
Mine have been in for about 4 years and have not had any problems with bolts loosening up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">You get so used to it after a while that you think that cars without them don't have motors and run solely on hopes and dreams.</TD></TR></TABLE>
it's like you took the words right out of my mouth!
i have had mine in for a year now and i have never had this problem. do you just tighten the bolts up or do you tourqe them down
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorteg_96 »</TD></TR><TR><TD CLASS="quote">i have had mine in for a year now and i have never had this problem. do you just tighten the bolts up or do you tourqe them down</TD></TR></TABLE>
i torque em to spec.
its probably the engine/tranny i bought(condition unknown). a couple months back one of the side engine mount bolts snapped and when i pulled the motor we realized it had previously been helicoiled
. So i suspect that the motor/tranny i have, have been thru some kind of abuse i guess i dunno. And with the particular bolts that are coming loose(rear mount, tranny mount, front mount) it just makes me uneasy to have the inserts i guess. But its just a pita to remove.
yusoslo
Jan 28, 2004 07:22 PM
