Toda Headgasket
Old Sep 27, 2004 | 06:11 PM
EGkid's Avatar
Default Toda Headgasket
Sup guys, i was thinkin of running a toda 1-layer headgasket on my lsvtec setup with gsr head. I'm also running toda b cams and i was wondering if i would be safe with a 1 layer headgasket and how much cam tuning i'd have without running into any trouble.
Old Sep 27, 2004 | 07:48 PM
EGkid's Avatar
Default Re: Toda Headgasket (EGkid)
anybody??? please
Old Sep 28, 2004 | 09:27 AM
EGkid's Avatar
bump
Old Sep 28, 2004 | 11:51 AM
Enrikez's Avatar
i think their headgakets are only to be used when running their pistons. do they even have a one layer? i remeber going to their site and seeing that their headgaskets would decrease compresssion, not raise it.
from the site: "With ever improving tuning technology, the pressure increases found in the combustion chamber can become a problem. Improved gas sealing is a high priority when increasing the power output of any engine. Should be used with TODA forged pistons. The 0.6mm gaskets are the same thickness as stock and do not affect the compression ratio, but the 0.8mm and 1.0mm gaskets lower the compression ratio"
mugen headgasket works for me. cheaper than toda. also i heard but havent tried...removing middle layer from a stock headgasket is the same **** as mugen
Old Sep 28, 2004 | 12:07 PM
92RED Hatch's Avatar
Default Re: Toda Headgasket (1meanB18c5civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1meanB18c5civic &raquo;</TD></TR><TR><TD CLASS="quote">i think their headgakets are only to be used when running their pistons. do they even have a one layer? i remeber going to their site and seeing that their headgaskets would decrease compresssion, not raise it.
mugen headgasket works for me. cheaper than toda. also i heard but havent tried...removing middle layer from a stock headgasket is the same **** as mugen</TD></TR></TABLE>
This isn't true......the 0.6mm one is to stock specs and the other two will raise the compression. There is even a chart on this at inlinfour.com....here is the link to see it..http://www.inlinefour.com/todbservtecm.html
Old Sep 28, 2004 | 03:27 PM
Enrikez's Avatar
Default Re: Toda Headgasket (92RED Hatch)
read Inline fours site again. it is an exact copy of todas site.
ONCE AGAIN, from Toda's site: With ever improving tuning technology, the pressure increases found in the combustion chamber can become a problem. Improved gas sealing is a high priority when increasing the power output of any engine. Should be used with TODA forged pistons. The 0.6mm gaskets are the same thickness as stock and do not affect the compression ratio, but the 0.8mm and 1.0mm gaskets LOWER the compression ratio.
the 0.6mm is stock spec, the nest two sizes are .8mm, them 1.0 mm
How is the thicker headgasket going to raise compression?
Old Sep 28, 2004 | 03:59 PM
haha whoops man..sorry I am being totally retarded......must excuse me I'm gonna blame it on the oxycodone narcotic that I was on when I posted that mess. Bad motorcycle accident...Long list of broken body parts....again sorry for my not thinking..
Old Sep 28, 2004 | 04:12 PM
EGkid's Avatar
okay so now that we've figured out that toda doesn't make a 1 layer....CAN i run a 1 layer headgasket and be fine?
Old Sep 28, 2004 | 07:24 PM
Enrikez's Avatar
you can but....this is definetely an example of when you should clay for clearances. just for the sake of not being able to adjust cams more than a degree or so. depends also on what pistons, milled head? etc..a few factors involved. i know you wanna definite answer, but i wouldnt risk blowing my inve$tment just cause one guy said YES YOU DEF. CAN RUN THAT GASKET.
just play it safe
Wannabe JDM
Jan 19, 2007 11:18 PM
WH0R3nEF9
Jan 7, 2006 08:17 AM
jaydmcrx
Jan 27, 2004 12:56 PM
WayneGro
Oct 26, 2001 04:15 PM
