Car got stolen, recoveredm need new ignition lock now.
Old Sep 27, 2004 | 05:42 PM
NiBlazed's Avatar
Default Car got stolen, recoveredm need new ignition lock now.
Alright well my 95 accord got stolen as i mentioned in this thread https://honda-tech.com/zerothread?id=1003035
It was found at a hotel parking lot.
But now i need a new igntion lock assmebly since it was poped out. I still have the lock itself, but im wondering how much should it cost to get it fixed. Theres also an electrical board which im guessing goes with the lock, and that got cracked.
Thanks
Old Sep 27, 2004 | 05:47 PM
madd's Avatar
Default Re: Car got stolen, recoveredm need new ignition lock now. (NiBlazed)
this isnt going to help you, but congrats on getting it back
Old Sep 27, 2004 | 06:04 PM
bodiez's Avatar
Hit the floor!
Default Re: Car got stolen, recoveredm need new ignition lock now. (madd)
Same thing, its awesome you got your car back.
Old Sep 27, 2004 | 07:25 PM
91EXRMANUAL
Guest
Posts: n/a
Default Re: Car got stolen, recoveredm need new ignition lock now. (bodiez)
Well , the bolts on a 90 are not accessable (you might need a tool) the way i changed mine , i removed the steering wheel and removed the whole steering assemby and bashed the f'n thing with a hammer untill it came off and replaced it with a new one.
have fun
{im assumeing that just the lock is off so now you could just start it with a butter knife if you want!}
Old Sep 28, 2004 | 03:56 PM
NiBlazed's Avatar
Default Re: Car got stolen, recoveredm need new ignition lock now. (91EXRMANUAL)
Yea i use a screw driver to start it now. There was actually a butter knife left in the car when i got it.
Anyway yea the lock is poped out, the plastic coloum is cracked a little, and that electric board is broken to. How much are the parts for that? Do i need to buy the whole assembly which is like $130 ?
Old Sep 28, 2004 | 03:57 PM
madd's Avatar
hope this helps...
http://www.hondaautomotiveparts.com/
Old Sep 28, 2004 | 08:34 PM
judonoh's Avatar
it's real simple. The old lock assembly has to come out, there are two blank bolts that hold it in. You can either drill them out or use some thing to cut the head off(air hammer, grinder). Make sure that all the wires are disconnected and that the battery is undone first(don't want the bag going off). The new assemble uses breakaway bolts. Re-connect the wires and your done.
Old Sep 28, 2004 | 08:47 PM
91EXRMANUAL
Guest
Posts: n/a
Default Re: Car got stolen, recoveredm need new ignition lock now. (judonoh)
its so easy to break these things off. i busted one with the tire iron in the trunk.. its all cast iron..
Slomo_civic
12
Apr 20, 2012 07:06 PM
salvi2dafullezt
Oct 12, 2009 03:01 PM
EK9Tune
Audio / Security / Video
Nov 6, 2008 11:19 AM
punkracer
Jul 12, 2005 09:51 PM
IDGAF2885
13
Apr 21, 2005 07:18 PM
