jdm d15b swap on an EF/CRX
My friend, Ghettoassrex, found an awesome deal for a jdm d15b (sohc vtec) and has a few questions about the swap. His car is an '88 CRX Si and wants to know what wire harness he needs to get. He heard from a seller that his stock wiring harness works with the motor, but he's not too sure about it. My friend also wants to know what ecu would work with the motor. Anyone with this swap, please give me or him a PM. Thanks a lot!
it will work......
he will need:
rpm activated switch for vtec
and he will have to wire the vtec solenoid and pressure switch to the ecu, he can keep the stock ecu, but he will need to switch to a d16a6 dizzy onto the d15vtec and obd-0 injectors..
someone correct me if im wrong?
he will need:
yeah just go obd1 i have basicly the same motor in my hatch xcept its a d16z6
u need
4wire o2
correct dizzy
p28 ecu
obd0-1 jumper harness
then just wire up 8 extra wires that come from the obd jumper harness. wire up the injectors 92-95 style and ur done
u need
4wire o2
correct dizzy
p28 ecu
Drew Lowe
Jul 18, 2014 04:52 AM
