what the fork?
Old Sep 27, 2004 | 02:26 PM
Btothe3rdDegree's Avatar
Default what the fork?
so i think my clutch fork popped out of place, i drove my car the other day and it ran fine, the next day i would not go into gear, and the clutch resivoir levels are fine. if that is the case do i need a new fork? or was it a freak accident?
Old Sep 27, 2004 | 02:50 PM
soundbomber's Avatar
Default Re: what the fork? (Btothe3rdDegree)
that's forked up
Old Sep 27, 2004 | 03:13 PM
EG_Civic_Si's Avatar
Default Re: what the fork? (soundbomber)
bwah ha ha ha ha !
Old Sep 27, 2004 | 03:15 PM
93vxhatch's Avatar
that is forkin' crazy have you ever had this problem before?
Old Sep 27, 2004 | 03:24 PM
Default Re: what the fork? (93vxhatch)
anyways, back to the forkin program motherforkers, does it go into gear now or nah?
Old Sep 27, 2004 | 03:32 PM
spyderracing's Avatar
Uhhh fix it?
(Avoids jumping on the forkin band wagon, and sees it as the next JDM!! )
Old Sep 27, 2004 | 03:56 PM
Default Re: what the fork? (spyderracing32)
LoL....yes please back tot he problem at hand. anyone help this guy?
Old Sep 27, 2004 | 05:21 PM
Default Re: what the fork? (EG_Civic_GSR)
ohh what the fork!!!
i am guessing the fork just popped out? or is it something else?
Old Sep 27, 2004 | 05:50 PM
Deemeetree's Avatar
Electrician
Have you forking tried to rule out all forking things such as the forking bushings, the forking linkage and the forking fork? Have you checked if the fork is forking engaging? Fork man...do some troubleshooting.
<FONT SIZE="20">FORK!</FONT>
Old Sep 28, 2004 | 09:40 AM
Default Re: (Dimi)
well i replaced the throwout bearing and made sure the fork was still in place, bleeded the clutch and the bitch still wont go into gear, please anyone know what is going on?
Old Sep 28, 2004 | 09:45 AM
jdm123's Avatar
Default Re: (Btothe3rdDegree)
you might have bent the fork bad
Old Sep 28, 2004 | 09:48 AM
Default Re: (jdm123)
no i took it out the fork looks fine
Old Sep 28, 2004 | 10:02 AM
Grimm's Avatar
could be synchro's
Old Sep 28, 2004 | 10:03 AM
ej1 pilot's Avatar
did you fork with any of the bolts besides the trans housing bolts? one bolt in there if not properly aligned can block you out of gears
Old Sep 28, 2004 | 10:21 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree &raquo;</TD></TR><TR><TD CLASS="quote">no i took it out the fork looks fine</TD></TR></TABLE>
I haven't taken my Civic tranny off yet so I'm exactly sure what it looks like but I assume it's relatively the same as my Accord tranny. If so, there is a fork that pushes the throwout bearing onto the diaphragm of the pressure plate when you press on the clutch pedal. Is this the fork you are saying is fine? If so, have you checked the shift forks inside the tranny?
Old Sep 28, 2004 | 07:35 PM
Default Re: (TouringAccord)
see i dont get it it WORKED one day and the next it didnt work, with the car shut off it goes into gear fine, all of them. once the car is on it wont. i have never delt with a tranny problem so bare with me. but doesnt it sound like the clutch is not disengaging? i really need help
Old Sep 28, 2004 | 07:36 PM
Default Re: (Art In Motion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art In Motion &raquo;</TD></TR><TR><TD CLASS="quote">did you fork with any of the bolts besides the trans housing bolts? one bolt in there if not properly aligned can block you out of gears</TD></TR></TABLE>
nope didnt mess with anything
Old Sep 28, 2004 | 08:19 PM
AsianMullet's Avatar
does it shift when the car is off? if so...could be a clutch problem
Old Sep 28, 2004 | 09:04 PM
SOHC4life 96's Avatar
Default Re: (EKchump)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Have you forking tried to rule out all forking things such as the forking bushings, the forking linkage and the forking fork? Have you checked if the fork is forking engaging? Fork man...do some troubleshooting.
<FONT SIZE="20">FORK!</FONT></TD></TR></TABLE>
BWHAHAHAHAHAHA, read through this whole thread, then go pick up a for (the eating utensils[sp]) I GUARANTEE you will laugh.
Old Sep 28, 2004 | 09:22 PM
allmotorEG-SI's Avatar
In my crx i had trouble getting it into gear befor, its was the forking snycros that went bad. I had to replace the whole forking tranny. ($300)
Old Sep 29, 2004 | 07:25 PM
Default Re: (allmotorEG-SI)
could the clutch pedal need adjustment?
Old Sep 29, 2004 | 07:29 PM
Deemeetree's Avatar
Electrician
Default Re: (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life &raquo;</TD></TR><TR><TD CLASS="quote">
BWHAHAHAHAHAHA, read through this whole thread, then go pick up a for (the eating utensils[sp]) I GUARANTEE you will laugh.</TD></TR></TABLE>
I'm glad you feel that way. My job is done here.
Old Sep 29, 2004 | 07:37 PM
blaster834's Avatar
Wont go into any gears or just first?
Old Sep 30, 2004 | 04:29 AM
Default Re: (blaster834)
any gear
Jtuned
Jan 31, 2006 03:37 PM
elips0id
Apr 1, 2004 03:38 PM
D15VTEC
Mar 19, 2003 05:17 AM
Jmm0056
Sep 12, 2001 01:54 PM
