CTR pistons on my LS?
Old Sep 27, 2004 | 12:59 PM
TeGGY_LS's Avatar
Default CTR pistons on my LS?
been reading the archives and ppl say that this is the 2nd best mod to an all-motor LS, 1st being a b16 tranny......since i already have the tranny, my question is with my compression this high will i pass emissions?
Old Sep 27, 2004 | 01:36 PM
Yambor's Avatar
Default Re: CTR pistons on my LS? (TeGGY_LS)
JDM B16A SiR2 (P30) pistons mate right to the ls rod without milling the small end 1mm.
Old Sep 27, 2004 | 02:24 PM
patmcd's Avatar
Default Re: CTR pistons on my LS? (Honda2nr4life)
I wouldnt think that you would have a problem passing emmissions as long as you get your car tuned properly.
Old Sep 27, 2004 | 04:16 PM
TeGGY_LS's Avatar
Default Re: CTR pistons on my LS? (patmcd)
TTT
Old Sep 27, 2004 | 05:18 PM
kNOwLedGeDA9
Guest
Posts: n/a
CTR (PCT) pistons in your B18A/B is not a good idea. Your compression will be well over 12:1, and no matter how much tuning you do, pump gas will not be your friend. Your compression ratio doesn't NECESSARILY affect your emissions. Overall, he P30 pistons are your best bet because they give you a good all around compression ratio and no modification is needed to mate them to your PR4 rods. Good luck
Old Sep 28, 2004 | 09:55 AM
TeGGY_LS's Avatar
Default Re: CTR pistons on my LS? (kNOwLedGeDA9)
thanks alot for the replys
Old Sep 28, 2004 | 09:57 AM
dip-set's Avatar
keep it alive...ttt
Old Sep 28, 2004 | 10:11 AM
TeGGY_LS's Avatar
Default Re: CTR pistons on my LS? (b18b-se)
where can i get a set of P30 pistons?
Old Sep 30, 2004 | 04:18 AM
NJcoupe's Avatar
from me..PM me
Old Sep 30, 2004 | 04:42 AM
arw321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGeDA9 &raquo;</TD></TR><TR><TD CLASS="quote">CTR (PCT) pistons in your B18A/B is not a good idea. Your compression will be well over 12:1, and no matter how much tuning you do, pump gas will not be your friend. Your compression ratio doesn't NECESSARILY affect your emissions. Overall, he P30 pistons are your best bet because they give you a good all around compression ratio and no modification is needed to mate them to your PR4 rods. Good luck </TD></TR></TABLE>
I run PCT's in my LS on pump gas. The car runs great. Please don't spread misinformation.
My car is currently untuned, 16 deg ignition timing on 94 octane. I'm ensuring my motor is fully broken in before dyno tuning... so, no, I'm not overly hard on my car right now.. the odd 7500 RPM shift... but nonetheless, I have no major detonation problems and my plugs look great.
The only problem I have with the high compression is a VERY slight ping under load below 2000 RPM. My solution is to not put the motor under load below 2000 RPM.
Old Sep 30, 2004 | 08:49 AM
TeGGY_LS's Avatar
ttt
Old Oct 1, 2004 | 08:34 AM
DarthVtec's Avatar
i just did a little converting of my motor. i took out the stock b18b1, and put in a b18b1 with ctr pistons and a b16 head. my compression is way to high, the motor pings, the car is slower, im disapointed. i think im gonna put the b16 head on my stock ls block. i cant afford to run expensive gas. i should have researched better. this is just my opinion, but i wouldnt use ctr pistons unless you can afford the fuel. just my opinion.
Old Oct 1, 2004 | 02:10 PM
genetsang's Avatar
just curious what year car? and what year motor?
b/c i did private nj state inspection and "failed" because i was running a odb1 ecu in a obd2 motor/car.
dam the new emission laws
Old Oct 1, 2004 | 02:47 PM
TeGGY_LS's Avatar
Default Re: CTR pistons on my LS? (genetsang)
97 LS
Gam3_Ov3r
Aug 29, 2007 07:33 AM
203_DC5
Feb 15, 2007 11:35 AM
N20civicB18
Jul 27, 2004 08:15 AM
ID_ten_T
Jun 15, 2003 04:14 PM
MXPX
Jun 20, 2001 06:33 PM
