d16y8 into a DX EG hatch....please help!!
I wanted to pick up a sohc vtec engine and it seems y8s are easier to find than z6s where i am but because its a obd-ii i had some questions. after doing searches i couldnt find a write-up or topic directly related to the swap itself. so can someone help answer some of my questions.....
I'm basically just worried about the wiring....its the one part of motors that i suck on.....so from what i read from various posts i can use my 94 dx wiring harness right? just have to wire up the knock sensor, vtec, and oil pressure and use the p28? would i have to switch any plugs off the engine itself and use the plugs off my existing motor? will the fuel injector plugs off the wire harness work on the injectors on the motor? any info pertaining to this swap will be greatly appreciated. thanks!!
crazyowes2000
Sep 28, 2011 06:18 AM
