Are 225-50-15 BFG Comp T/A Drag Radials too much for my 4G VTEC?
Old Sep 27, 2004 | 09:26 AM
vntperformance's Avatar
Default Are 225-50-15 BFG Comp T/A Drag Radials too much for my 4G VTEC?
Guys,
I have the stock 205x55x15 on my car right now... I want to be able to pull 1.9 and lower 60ft times on my prelude vtec.. my thing is which will better suit me in tires size with drag radials.
205-50-15 bfg comp t/a drag radials
225-50-15 bfg comp t/a drag radials
Thanks.
vnt
Old Sep 27, 2004 | 09:39 AM
Greyout's Avatar
Default Re: Are 225-50-15 BFG Comp T/A Drag Radials too much for my 4G VTEC? (vntperformance)
the 225's would be great, but they will bulge a bit.
the 205's would be shorter overall, which would help your gearing - with the narrow wheel, the difference in contact patch might be small enough to justify the narrower / shorter tire.
Old Sep 27, 2004 | 06:52 PM
Default Re: Are 225-50-15 BFG Comp T/A Drag Radials too much for my 4G VTEC? (Greyout)
so which should I use?
vnt
Old Sep 27, 2004 | 08:33 PM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vntperformance &raquo;</TD></TR><TR><TD CLASS="quote">so which should I use?
vnt </TD></TR></TABLE>
i like the bigger ones personally...but whats your mods...
Old Sep 28, 2004 | 08:27 AM
Default Re: Are 225-50-15 BFG Comp T/A Drag Radials too much for my 4G VTEC? (fastludeh22)
I/H/E
Spoon ECU w/8.5k Redline, Crower Stage 2 Cams w/Valvetrain and 67mm TB.
And ACT Clutch.
vnt
Old Sep 28, 2004 | 09:10 AM
BolivianFuego's Avatar
What up bro. What mods you got done to your toy? What power are you making? ANd i think you should be able to pull some good 60fts on 225s. Give it a shot.
Old Sep 28, 2004 | 09:40 AM
Default Re: Are 225-50-15 BFG Comp T/A Drag Radials too much for my 4G VTEC? (BolivianFuego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">What up bro. What mods you got done to your toy? What power are you making? ANd i think you should be able to pull some good 60fts on 225s. Give it a shot.</TD></TR></TABLE>
Mr.Fuego
I see your still around, we'll im back with another prelude.
should make about 190+fwhp with the crower stage2 cams.
vnt
Old Sep 28, 2004 | 10:41 AM
Xbstd23X's Avatar
im runnin the 225's on my 92 si and i like them alot
dont rub at all but im not lowered or anything
Old Sep 28, 2004 | 11:23 AM
Default Re: Are 225-50-15 BFG Comp T/A Drag Radials too much for my 4G VTEC? (Xbstd23X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xbstd23X &raquo;</TD></TR><TR><TD CLASS="quote">im runnin the 225's on my 92 si and i like them alot
dont rub at all but im not lowered or anything </TD></TR></TABLE>
drag radials or street tires??
if drag radials then what kinda 60fts are you pulling?
vnt
Old Sep 28, 2004 | 01:26 PM
Mr.Fuego
Awsome, and dont forget to warm up those Drag rads real good. Giving them a good burn out. Also on BFGs when the tire tread goes away it doesnt mean they are bad. They just turn into somewhat form of slicks.
Old Sep 28, 2004 | 01:29 PM
Xbstd23X's Avatar
im runnin the bfg drag radials
225 50 15
havent got to the track yet
you can tell hella dif. before i would break loose at the top of second and now i barely break loose in first
Old Sep 28, 2004 | 02:55 PM
ALTERED4's Avatar
the 205's will give you a smaller od, and will give you a slight advantage when it comes to acceleration, but the 225's will give you a wider contact patch, and that will help you with your off-the-line traction...
my 4th gen weighs about 2600 lbs and puts down about 185 hp. i pull 1.9's all day with my 22" mt et drags, and the et drags are a full slick. back when i was running drag radials, the best i could pull off was a 2.1. as the drag radials got older, my 60 ft times also declined...
Old Sep 28, 2004 | 03:13 PM
BolivianFuego
Don't worry I run them on my Supra TT, so i'm very familiar with em...
Xbstd23X
See any difference in MPH after switching to the bigger tire?
ALTERED4
What mods you got, your ETs look wonderful. Which would you recommend, the smalled Od or the wider patch? I wanna be able to hook but at the same time, no loose MPH. Back when I had my 5G Vtec and was launching at 5k, I would pull consistent 2.0s with Nitto DRS. (205-55-15)
regards.
vnt
Old Sep 28, 2004 | 03:36 PM
Xbstd23X's Avatar
i cant really compare mph cuz i got them put on 1 day after my turbo got put on so
Old Sep 28, 2004 | 03:45 PM
md23vtec's Avatar
225/50/15 BFG, G-force T/A drag radials are the best tire next to slicks I have came across 1.972 60.ft with about 14PSI just my 2cents . G-force T/A have much softer compound, if its used only when racing and not driven on daily you would get your best results I have found.
Old Sep 28, 2004 | 04:42 PM
Default Re: Are 225-50-15 BFG Comp T/A Drag Radials too much for my 4G VTEC? (md23vtec)
Xbstd23X
I hear that!
md23vtec
so what was your et? And what mods you got?
vnt
Old Sep 28, 2004 | 05:03 PM
md23vtec's Avatar
Sorry I dont put out my et's on the car. I stopped street racing now for a while but there is a jackass pissing me off with a turbo prelude thats goes 13.20's or so on slicks. It's no secret thats the old setup stock j.spec I/H/E high flow cat V-AFC dry shot of zex has been 12's on drag's (thanks to jinxproof now everbody knows ) But thats about all i'll give out.
I am doing a new setup now that will hopefully rank me as the fastest street legal prelude next season. #'s and dyno will be posted for that car and video's also thats if the motor gets finished anytime soon in Texas
Old Sep 28, 2004 | 05:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">Sorry I dont put out my et's on the car. I stopped street racing now for a while but there is a jackass pissing me off with a turbo prelude thats goes 13.20's or so on slicks. It's no secret thats the old setup stock j.spec I/H/E high flow cat V-AFC dry shot of zex has been 12's on drag's (thanks to jinxproof now everbody knows ) But thats about all i'll give out.
I am doing a new setup now that will hopefully rank me as the fastest street legal prelude next season. #'s and dyno will be posted for that car and video's also thats if the motor gets finished anytime soon in Texas</TD></TR></TABLE>
Good Luck!
vnt
Old Sep 28, 2004 | 05:12 PM
md23vtec's Avatar
Thanks you to. Another traction tip that works for me if your using the bottle dont rev up so high roll out slow and let the bottle pull the car it already has enuff power, If you can master that you almost pull any fwd out of the hole atleast on the street with g-force t/a. Whts your setup? Track car or street car?
Old Sep 29, 2004 | 04:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">Thanks you to. Another traction tip that works for me if your using the bottle dont rev up so high roll out slow and let the bottle pull the car it already has enuff power, If you can master that you almost pull any fwd out of the hole atleast on the street with g-force t/a. Whts your setup? Track car or street car?</TD></TR></TABLE>
My setup is listed above and only street car.
vnt
Old Sep 29, 2004 | 05:37 PM
md23vtec's Avatar
Oh ok sorry head in ***.. I personally dont like the chipped ecu myself hopefully you have better luck with then I have came across. Let me know what tires you run with and your results
danp1uk
Aug 26, 2010 10:04 AM
mike93eh2
Jan 30, 2008 08:32 AM
tyrone27
Oct 9, 2006 08:27 PM
PGT Driver
Oct 20, 2005 07:18 PM
austrian type-R
Aug 3, 2003 11:48 PM
