ENGINE "SHAKE" WHEN ENGAGING CLUTCH ON 93 ACCORD
Old Sep 27, 2004 | 09:24 AM
pba110's Avatar
Default ENGINE "SHAKE" WHEN ENGAGING CLUTCH ON 93 ACCORD
hey,
anyone know why this happens. i've got a 93 accord 4d lx with no modifications. about 130 k. clutch has never been changed. anyways, sometimes when i engage the clutch (usually when the engine is cold) in first gear the car begins moving but shaking like ****. i'm giving it plenty of gas, the rpms are around 1500 (so it's not choking) when it's happening. a buddy of mine thinks my motormounts have gone bad. i think i need a new clutch.
what do you think?
Old Sep 27, 2004 | 09:41 AM
brads94accord's Avatar
Default Re: ENGINE "SHAKE" WHEN ENGAGING CLUTCH ON 93 ACCORD (pba110)
its either bad motor mounts or clutch chatter. try to start your car on a hill in 3rd gear and if it stalls out, your clutch is ok, if it starts to rev a little bit and slip that means your clutch is going out.
Old Sep 27, 2004 | 09:51 AM
green98acc's Avatar
Default Re: ENGINE "SHAKE" WHEN ENGAGING CLUTCH ON 93 ACCORD (brads94accord)
I'd say bad tranny mount... first guess...
Old Sep 27, 2004 | 10:16 AM
Lostcb7's Avatar
Default Re: ENGINE "SHAKE" WHEN ENGAGING CLUTCH ON 93 ACCORD (green98acc)
I'm with brads94accord, I think it could be the motor mounts.
Old Sep 27, 2004 | 12:22 PM
Bantam's Avatar
2nd Coolest Person in DFW
Default Re: ENGINE "SHAKE" WHEN ENGAGING CLUTCH ON 93 ACCORD (Lostcb7)
do a search (google, here) you can repair broken mounts with polyurethane window weld. it comes in a long tube (for a caulking gun). its a very good option since new mounts will be about $100 each. you could probably do all of your mounts for a few hours labor and $30 for the window weld.
Old Sep 28, 2004 | 07:35 AM
90accorddx's Avatar
at that many miles i would just replace the clutch any way my car seemed to do the same thing i just put a new motor in over the weekend along with a new clutch and it definately made a difference
eromezab
Transmission & Drivetrain
Apr 26, 2014 08:57 PM
beat
Jun 12, 2009 01:21 PM
radiuslight
May 15, 2008 12:19 PM
kornerk12
Dec 20, 2005 05:47 AM
marky01lsteg
Jan 7, 2005 10:33 PM
