Maintenance Req'd??... what's this mean??
Old Sep 27, 2004 | 06:45 AM
halcyon82's Avatar
Default Maintenance Req'd??... what's this mean??
I know this might be a very basic question, but I'm a first accord owner (99 EX coupe). What does the maintenance req'd light mean?? is it something critical I should pay attention to?? I read the manual and it says this indicator comes on as a reminder for routine maintenance which I carrried out already at 117000mi, now it's at 119000mi... is there something the mechanic shoud have done after carrying out the maintenance??
HELP PLS!!!!
Old Sep 27, 2004 | 06:50 AM
phoenixitc's Avatar
Did the light start after the mechanic did the work? Some cars require the mechanic to reset the indicator. My Chevy Trailblazer had the same thing and can be reset by the owner.
Old Sep 27, 2004 | 07:12 AM
Justin Klemgold's Avatar
It means change your oil....
Old Sep 27, 2004 | 07:31 AM
sj993's Avatar
Default Re: (Justin Klemgold)
Just reset the light since you already did the maintence.
Old Sep 27, 2004 | 07:49 AM
JimBlake's Avatar
Default Re: (sj993)
Owner's manual says how to reset that light. You or the mechanic can't reset it until it's actually coming on. (For example if you did the oil change early.)
Old Sep 27, 2004 | 08:23 AM
raff418's Avatar
Default Re: Maintenance Req'd??... what's this mean?? (halcyon82)
the maintenance required light comes on every 7,500 miles to remind you to take ur car to the dealership so they can rip you off. to reset the light have the key out of the ignition. hold down the "trip reset" button and have it held down while you put the key back in and turn the ignition to the II position and do not let go until the maintenance required light turns off. you have to hold it down for like 10 or 15 seconds.
Nuts
Aug 29, 2008 08:28 AM
mrbsponge
Acura TL, RL & ZDX
Aug 16, 2007 03:52 PM
chiheat
Honda S2000
Jan 13, 2006 10:54 AM
Dave Slater
Oct 5, 2005 05:40 AM
Acc99ord
Mar 31, 2004 02:33 AM
