engine idleing weird
Old Dec 12, 2001 | 06:51 AM
lozersk8er's Avatar
New User
Default engine idleing weird
i just put a zc in my crx and when it is at idle it acts like it is going to die the it revs back and it does this over and over
Old Dec 12, 2001 | 07:11 AM
Spade's Avatar
Default Re: engine idleing weird (lozersk8er)
adjust the idle higher!!!! The ecu is feeding more fuel to keep it from dieing cause the idle is set too low.
should be a screw er somethin' on the trottle body.
[Modified by Spade, 8:12 AM 12/12/2001]
Old Dec 12, 2001 | 08:37 AM
rainforest's Avatar
Default Re: engine idleing weird (Spade)
or check the voltage on the tps also check for vacume leaks.
Old Dec 12, 2001 | 09:16 AM
lozersk8er's Avatar
New User
Default Re: engine idleing weird (joshbm)
its a 90 fuel injection and its not a vacum leak that i can find; i think it might be the atmosphere persure sensor because the zc doesnt have one that i could find
thanks
Old Dec 12, 2001 | 09:18 AM
lozersk8er's Avatar
New User
and where is the idle screw located? it does ok while the choke is in but once it heats up it does that idleing thing again
gregv
Jul 27, 2007 09:04 PM
b18hondahb
16
Oct 13, 2006 05:40 PM
crx1.6i
Oct 5, 2006 09:27 AM
civicracer1993
Apr 2, 2004 08:10 PM
lozersk8er
Dec 12, 2001 09:09 PM
